hi,
when iam running a script , frequently iam facing segmentation error. what might be the possibilities .
regards,
jamie
Hi Jamie
it is due to some of commands are sensitive to make appcrash
Hi Jamie it is due to some of commands are sensitive to make appcrash
so tinh how can i overcome that...or what changes should i make
Hi Jamie,
You have to detect which command is output to command.tcl last? then the next command in your script is sensitive.
Please show us a range of your codes around that command
TINH. actually ,once the tk message is displayed (highlited in the scripr).i get the segmentation error.
the error appeared after you clicked on OK button of the message box, didn't it?
Hi Jamie, the error appeared after you clicked on OK button of the message box, didn't it?
yes tinh
and the the exported file is not in proper format.
hey tinh..just now i removed that tk message..now its working..but how come tinh?
I see it calls proc napocomparison after clicking ok
could you show that proc?
I see it calls proc napocomparison after clicking ok could you show that proc?
the sensitive command is *findmark
I think the bit must not be 257
could you shift f5 and find some elems attached to some nodes then check what number is output to command.tcl?
as i remember, it is 1 or 0
Hi Jamie, the sensitive command is *findmark I think the bit must not be 257 could you shift f5 and find some elems attached to some nodes then check what number is output to command.tcl? as i remember, it is 1 or 0
tinh ,i dont find any difference in that command.
tinh ..anyway the commands above the findmark itself are not excuted.
HEY TINH .got the issue solved.....There was was no *createstringarray before the feinputwithdata command
