how the "Most Likely / Prediction" in Model Simulator calculated??
bniyaseen
New Altair Community Member
what the algorithm or the criteria were taken to find the Most Likely / Prediction. if I want to write it as science in a research paper.
0
Best Answers
Hi,It is the confidence level of the underlying machine learning model. Here is some more information:Technically only for the Bayes classifier the confidence equals a probablity but it has a similar meaning for all other models as well. For example in an SVM, the confidence is typically computed based on the distance of the data point to the separating hyperplane.Hope that helps,Ingo
1 -
First of all: please stop double posting. Spamming the community is not going to get you help faster, it will only annoy people.I would recommend to go through some data science training, our new Academy site may be useful: http://academy.rapidminer.comThis video in particular covers some of the questions you have but there is more to discover:A book like Elements of Statistical Learning may be helpful as well:Hope this helps,Ingo1
Answers
1 -
