"New RapidMiner 9.1 version prompts Deep Learning 0.90 is incompatible at start up"
buenaobrabj
buenaobrabj New Altair Community Member
edited November 2024 in Community Q&A
I'm trying out an educational license with the new RapidMiner 9.1 installed everything available at the market place extension to my surprise one the most important modeling scheme Deep Learning 0.9 is being flagged as incompatible? What could be the problem? I just opted to ignore it after installation but not so sure if its going to work?
Answers
  • hughesfleming68
    hughesfleming68 New Altair Community Member
    edited December 2018
    In most cases this has to do with the Anaconda path. Removing it solved the problem for me without causing any problems elsewhere. Take a look at this thread where there is a discussion about this. The new Deep Learning extension is working in 9.1. The fact that it can automatically figure out the input shape makes it much more usable than the Keras extension.
  • MartinLiebig
    MartinLiebig
    Altair Employee
    Hi,
    did you install Text Mining Extension? I think the new one relies on it.
    BR,
    Martin
Welcome!
Welcome!
