Community & Support
Learn
Marketplace
Menu
Menu
Home
Discussions
Community Q&A
How do you undo a subprocess?
figueroajc
New Altair Community Member
Dec 14, 2018
Updated
Nov 5, 2024
by
Jocelyn
Is there a way to get rid of a subprocess so that what is inside is part of the main process again
AI Studio
Grouping + Subprocesses
All Replies
Accepted Answers
Sort by
Oldest
1 - 4 of 4
1
David_A
Accepted Answer
Dec 14, 2018
Hi,
if the changes are recent, you can simply hit
ctrl+Z.
If not you can simply cut out the operators and paste them in the top process.
Hope that helps.
sgenzer
Altair Employee
Accepted Answer
Dec 14, 2018
Updated
Dec 14, 2018
by
sgenzer
yep. Or just "cut" the operators inside the subprocess, delete the subprocess, and then paste in the main process. Either way.
Scott
figueroajc
OP
Dec 14, 2018
thanks!
Ram_20323
Altair Employee
May 15, 2023
I had this question today in RM10.1.001 and managed to do a CtrlZ to undo a sub-process. Is there a better solution than this?
Sort by
Oldest
1 - 2 of 2
1
David_A
Accepted Answer
Dec 14, 2018
Hi,
ctrl+Z.
Hope that helps.
View in context
sgenzer
Altair Employee
Accepted Answer
Dec 14, 2018
Updated
Dec 14, 2018
by
sgenzer
Scott
View in context
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
日本語 (Japanese)
한국어(Korean)
Groups
if the changes are recent, you can simply hit ctrl+Z. If not you can simply cut out the operators and paste them in the top process.
Hope that helps.
