Export error 19622: Export failed: Entity below box limits.
User: "Shan25_22239"
Altair Community Member
Updated by Shan25_22239
I am trying to export the surface in the attached model as an iges file.  I always get the following error message "Error 19622: Export failed: Entity below box limits.'
Can you please have a look at the model and let me know how to resolve this issue
1 - 5 of 51
    User: "Madelé"
    Altair Employee
    Updated by Madelé
    @Shan25, if you union all parts (or just union the two parts Spin1 and Subtract2) before exporting, the export should succeed. Please try and let us know if that is a viable solution for you.
    OP
    In the new attached file, I just have a single geometry 'subtract2' and when I export the surface as an Iges file I still the same error message.
    User: "Mel"
    Altair Employee
    Updated by Mel
    We have confirmed the error.
    A developer will have to investigate. Unfortunately difficult to give a time-frame for that.
    User: "Mel"
    Altair Employee
    Updated by Mel
    A workaround is to split the model, Union and then export. Nevertheless, this problem will be addressed.
    OP
    Thanks It is a good workaround!
