Local Stiffness Matrix for each Element
User: "alexander.scheible"
New Altair Community Member
Updated by alexander.scheible
Hello,
is it possible to get the local Stiffness Matrix of each element?
I need this matrix in an optimization step.
Thank you
Alex
1 - 3 of 31
    User: "tinh"
    Updated by tinh
    I see some posts about output k matrix of full model only
    Can you calculate element k matrix from it shape and properties?
    OP
    Hello,
    I want to avoid that.
    But if there is no other way I could do this.
    User: "etrud011"
    Updated by etrud011
    Hello,
    I would like to extract the local stiffness elements as well to compare my FE implementation to Optistructs. Is there a method to do this?
    Thanks,
    -Eric
