1 - 11 of
111
Yes, good question, sgenzer, actually, I am a PhD candidate and as
per the requirement of Journal's reviewer that if I calculate the
accuracy up to 3 or 4 digits after decimal so, it would be good to
identify the best performance algorithm. But, indeed it is not as
important but it is required by one of the reviewer. Thanks,
Raza.@razaabdi. If you set the fraction digit numbers in the preferences to a higher number then you will increase the number of decimal places of the performance operator.
Thanks a lot hughesfleming68 for your valuable answer, I have changed it to five digits but it only affects AUC value not accuracy, precision, recall, f-measure, sensitivity, and specificity. Actually, my utmost requirement is four significant figures after decimal in accuracy. Please help me. Thanks,
yes sorry @razaabdi I did not answer before but happy you have a good solution. If your journal reviewer needs a refresher course in significant figures, let me know
Thx @hughesfleming68 - forgot about that setting!
Scott
Scott
1 - 1 of
11
I am sorry razaabdi, you need to also set the fraction digit pecent values higher. It is still in the Number Format section.
Scott
