Execute R Script ARIMA Process Fails
New Altair Community Member
Updated by Jocelyn
Hi,
I'm trying to use R to build ARIMA model forecast with it. The script works well in R software, but when I try to use in Rapidminer with Execute R I always get an error message (bellow the detailed message).
I try to adapt an example process with R script to train and forecast with ARIMA, I found in Rapidminer.
Both, my script and the example, return the same error message.
Note: With other processes that use Execute R, like the tutorials, seems that there is no issue.
Enclosed the process.
Thanks for your help,
Pedro
Error message details:
Pedro
Exception: com.rapidminer.operator.OperatorException
Message: Script terminated abnormally.
Stack trace:
com.rapidminer.extension.rscripting.operator.scripting.AbstractScriptRunner.run(AbstractScriptRunner.java:166)
com.rapidminer.extension.rscripting.operator.scripting.AbstractScriptingLanguageOperator.doWork(AbstractScriptingLanguageOperator.java:90)
com.rapidminer.extension.rscripting.operator.scripting.r.RScriptingOperator.doWork(RScriptingOperator.java:73)
com.rapidminer.operator.Operator.execute(Operator.java:1025)
com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:812)
com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:807)
java.security.AccessController.doPrivileged(Native Method)
com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:807)
com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:428)
com.rapidminer.Process.execute(Process.java:1322)
com.rapidminer.Process.run(Process.java:1297)
com.rapidminer.Process.run(Process.java:1183)
com.rapidminer.Process.run(Process.java:1136)
com.rapidminer.Process.run(Process.java:1131)
com.rapidminer.Process.run(Process.java:1121)
com.rapidminer.gui.ProcessThread.run(ProcessThread.java:65)
1 - 8 of
81
hughesfleming68
Updated by hughesfleming68
Try putting library(forecast) before the rm_main = function(data) and take out the require(forecast). See if that works. It is helpful to include your data as well as it makes it easier to reproduce your error. Also some details like OS, R version etc.
Hi hughesfleming68, I put library(forecast), but got the same error message.
OS: Windows 7 Professional / Version 6.1.7601 Service Pack Build 7601
RM Version: RM Studio Free 9.0.003
Enclosed the data
Enclosed the data
Take a look at the fixed process. The problem started with the date format. The Date to Nominal operator fixed that.
Hi hughesfleming68, many thanks for your help. It is solved.
RM is indeed a very good software, but it is a community like this that led me to persuade my bosses to acquire RM.
Thank
Thank
Thank as a lot!
Thank as a lot!
Hi @hughesfleming68 and @pedrodomingosdv!
We know that the date conversion in the R extension is a problem right now and are working on it. But it's good to see that you found a workaround.
Cheers
Jan
1 - 1 of
11
Thank
Thank
