Scaling Input variables
User: "Akhil_22546"
Altair Community Member
Updated by Akhil_22546
Hello Community,
I have 7 input variables and would like to do a DOE. I have specified 10 discrete values but instead of all the combinations I would like to just have the input variables change together. So it evaluates 1st value for all input variables as a combination then 2nd values of all the input variables and so. Giving me just 10 unique iterations. I have tried using Interactions in the specifications but did not manage to get it to work.
Thanks for the time and help.
1 - 2 of 21
    User: "Michael Herve"
    Altair Employee
    Accepted Answer
    Updated by Michael Herve
    Hello @Akhil ,
    the sampling you want to set up is not exactly a DOE, it looks like a set of differetnt configurations? What you are looking for seems to be Sweep analysis from Basic Approach:
    Can you please test this approach? Does that help?
    Best Regards,
    Michael
    User: "Akhil_22546"
    OP
    It is exactly what I needed, Thank you so much.
