Hi Nishendra,
I saw your model and I also try to model from L1 to L5 for my studies. I have some models but I couldn't seperate them into shell and core parts as in your model. How do you model them as core and shell parts? Which program did you use for this?
Hi Nishendra,
I used ansys spaceclaim direct modeller for this purpose
Hi, i am unable to play this video, can you please upload it in a google drive link and share it. Thanks for your help!
Hi Nishendra,
Thank you! In spaceclaim direct modeller, I could form shell inner surfaces from my solid vertebra model by using shell offset. However, I couldn't export them as .iges files. Which format did you prefer to export them into Hypermesh? Could you help me with your experience about this situation, please?
For CAD format, you can export to STEP, IGES or Parasolid.
After I formed inner shell surfaces (facets) from my solid vertebra model by using shell offset in spaceclaim direct modeller, spaceclaim serves .obj, .stl and etc. formats not .iges, .step or other cad formats. So, I couldn't load it into Hypermesh.
Hey Guys! ,
I obtained the inner offset shell surface from Spaceclaim (Nishendra said before) as .stl format. Then, I converted it to .igs by using Geomagic Design X. Thus, I can transfer it into Hypermesh.
Kind regards,
Hey Guys! ,
Kind regards,
Hi,
You can convert the shell to solid in Spaceclaim itself. Right click on your component in the model tree, and click convert to solid. Then you can export it in any of the cad format.
I also trying to do this in Abaqus. In literature, people did it with Hypermesh or IA-FEmesh but there is no details about this modeling. Good question!
