🎉Community Raffle - Win $25
Join and Win
Visualization - transparency of solid elements
User: "Rahul_P1"
Altair Employee
Updated by Rahul_P1
I'm trying to check penetration between two solid parts. I have two questions, the answers to which will help me visually identify penetration more easily:
1) How do you change the transparency of a part with solid elements? The geometry transparency option on the visualization toolbar only changes the transparency for surfaces, not solid elements.
2) Is it possible to view some parts as shaded and others as wireframe at the same time?
Thanks.
1 - 4 of 41
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    Hi,
    In model browser you should see a meshed cube as shown below. Right click on the cube and you will see FeStyle options. Select Transparent from the available to make the elements in that particular component as transparent. Alternatively, press X on your keyboard which leads to Visual Atributes option.
    Select the transparent icon and select the component to turn the elements in that component to transparent.
    You can actually use the penetration check option available from tools page to check and automatically fix the penetrations and intersections.
    go to tools page-->Penetration to access the panel.
    several options are available in that where you can visualize/review elements which are intersecting or penetrating
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    To see the fe style icon (the meshed cube described above) for each component, you need to right click on the model browser and go to configure browser, once here, check the fe style and if necessary the geom style check boxes
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    Thanks for the help.
    User: "Merula_20758"
    Altair Community Member
    Updated by Merula_20758
    Top! Thanks!
