🎉Community Raffle - Win $25
Join and Win
Text Mining of multiple PDF files with separate key word counts
User: "bazi66"
New Altair Community Member
Updated by Jocelyn
Hello all,
I am new to this community and hope that somebody can help me. I already searched the forum a lot and found very good topics, but I couldn't find a proper solution for my task. Here's what I want to do:
I have about 500 PDF files and want to text mine them and compare the results to key words I already have in Excel.
The problem is, that I want to get a word count and a comparison for each PDF file (not overall) and a column for the results in an Excel Sheet. When I start my process with the "Process from Files" with a "Tokenize" operator in it, I only get back the sum over all documents, but not for each PDF file.
I already tried it with a different approach: A "Loop" operator, starting with the "Read from document" Process. I got no results out of that.
I attached my approaches (I use RapidMiner Studio). Can someone maybe help me with the right approach and the correct process map?
Thank you very much for your help in advance!
1st approach::
<?xml version="1.0" encoding="UTF-8"?><process version="9.0.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.0.001" expanded="true" name="Process">
<parameter key="resultfile" value="C:\Users\User\Desktop\hello.xls"/>
<process expanded="true">
<operator activated="true" class="text:process_document_from_file" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Files" width="90" x="45" y="136">
<list key="text_directories">
<parameter key="Berichte" value="C:\Users\USER\Dropbox\Dropbox\Masterarbeit\"/>
</list>
<parameter key="file_pattern" value="true"/>
<parameter key="extract_text_only" value="false"/>
<parameter key="keep_text" value="true"/>
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="112" y="34"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
<operator activated="true" class="text:wordlist_to_data" compatibility="8.1.000" expanded="true" height="82" name="WordList to Data" width="90" x="313" y="187"/>
<operator activated="true" class="write_excel" compatibility="9.0.001" expanded="true" height="82" name="Write Excel" width="90" x="514" y="238">
<parameter key="excel_file" value="C:\Users\User\Desktop\Test1234.xlsx"/>
</operator>
<connect from_op="Process Documents from Files" from_port="example set" to_port="result 2"/>
<connect from_op="Process Documents from Files" from_port="word list" to_op="WordList to Data" to_port="word list"/>
<connect from_op="WordList to Data" from_port="word list" to_port="result 3"/>
<connect from_op="WordList to Data" from_port="example set" to_op="Write Excel" to_port="input"/>
<connect from_op="Write Excel" from_port="through" to_port="result 1"/>
<portSpacing port="sink_result 3" spacing="0"/>
<portSpacing port="sink_result 4" spacing="0"/>
</process>
</operator>
</process>
2nd approach:
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<operator activated="true" class="loop_files" compatibility="6.4.000" expanded="true" height="82" name="Loop Files" width="90" x="45" y="34">
<parameter key="directory" value="C:\Users\USER\Dropbox\Dropbox\Masterarbeit\"/>
<parameter key="file_name_macro" value="file_name_TEST"/>
<operator activated="true" class="text:read_document" compatibility="8.1.000" expanded="true" height="68" name="Read Document" width="90" x="45" y="30">
<parameter key="content_type" value="pdf"/>
</operator>
<operator activated="true" class="text:process_documents" compatibility="8.1.000" expanded="true" height="103" name="Process Documents" width="90" x="45" y="136">
<parameter key="add_meta_information" value="false"/>
<parameter key="prune_below_rank" value="5.0"/>
<parameter key="prune_above_rank" value="5.0"/>
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="45" y="120"/>
</process>
</operator>
<operator activated="true" class="text:wordlist_to_data" compatibility="8.1.000" expanded="true" height="82" name="WordList to Data" width="90" x="45" y="255"/>
<operator activated="true" class="write_excel" compatibility="9.0.001" expanded="true" height="82" name="Write Excel" width="90" x="380" y="289">
<parameter key="excel_file" value="C:\Users\USER\Desktop\Test1234.xlsx"/>
</operator>
<connect from_port="file object" to_op="Read Document" to_port="file"/>
<connect from_op="Read Document" from_port="output" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Process Documents" from_port="word list" to_op="WordList to Data" to_port="word list"/>
<connect from_op="Write Excel" from_port="file" to_port="out 1"/>
<portSpacing port="source_file object" spacing="0"/>
<portSpacing port="source_in 1" spacing="0"/>
<portSpacing port="sink_out 1" spacing="0"/>
<portSpacing port="sink_out 2" spacing="0"/>
</process>
</operator>
<connect from_op="Loop Files" from_port="out 1" to_port="result 1"/>
</process>
</operator>
</process>
1 - 5 of 51
    User: "Pavithra_Rao"
    @bazi66,
    I think 2nd approach will be more appropriate here. It requires a small change is in the process flow here.
    Place the Write excel operator outside 'loop files' operator with a 'Append' operator. This way you are getting the list of words in every pdf file into one excel sheet. Here is the updated process. Hope this helps.
    If you are still getting errors, please share the 2 or more pdf files here so we can take a look at it in detail.
    <operator activated="true" class="write_excel" compatibility="9.0.001" expanded="true" height="82" name="Write Excel" width="90" x="648" y="34">
    <parameter key="file_format" value="xlsx"/>
    <parameter key="encoding" value="SYSTEM"/>
    <parameter key="sheet_name" value="RapidMiner Data"/>
    <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
    <parameter key="number_format" value="#.0"/>
    </operator>
    </process>
     Cheers,
    User: "bazi66"
    OP
    Hi,
    thanks for your quick response. Unfortunately I still don't get the expected result. The Excel file of the result contains 3 columns: word, in documents, total. I need the columns: word, count in PDF1, count in PDF2,..., total. A separate excel sheet/workbook for every PDF with the 3 columns would also be fine for me. I attached the code and 2 example PDFs. Thank you for your help!
    Code:
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="loop_files" compatibility="6.4.000" expanded="true" height="82" name="Loop Files" width="90" x="112" y="34">
    <parameter key="directory" value="C:\Users\USER\Dropbox\Dropbox\1Masterarbeit\"/>
    </operator>
    </process>
    </operator>
    <connect from_op="WordList to Data" from_port="example set" to_port="out 1"/>
    </process>
    </operator>
    <operator activated="true" class="append" compatibility="9.0.001" expanded="true" height="82" name="Append" width="90" x="246" y="136"/>
    <parameter key="excel_file" value="C:\Users\USER\Desktop\Test123456.xlsx"/>
    </operator>
    <connect from_op="Loop Files" from_port="out 1" to_op="Append" to_port="example set 1"/>
    <connect from_op="Append" from_port="merged set" to_op="Write Excel" to_port="input"/>
    </process>
    </operator>
    </process>
    Thanks for sharing the files @bazi66. Here is the updated process XML. This will output 2 (for each pdf) different wordlists as CVS files. I'm using pdf file name extracted as 'file_name' macro to name the CSV files. Hope this helps.
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="loop_files" compatibility="9.0.001" expanded="true" height="82" name="Loop Files" width="90" x="112" y="34">
    <parameter key="directory" value="C:\Users\PavithraRao\OneDrive - RapidMiner\Desktop-RMUS-PRAO\test"/>
    </operator>
    <operator activated="true" class="text:process_documents" compatibility="8.1.000" expanded="true" height="103" name="Process Documents" width="90" x="246" y="34">
    <parameter key="create_word_vector" value="false"/>
    <operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="45" y="85"/>
    <operator activated="true" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases" width="90" x="179" y="85"/>
    <operator activated="true" class="text:filter_stopwords_english" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="313" y="85"/>
    <operator activated="true" class="text:filter_by_length" compatibility="8.1.000" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="514" y="85"/>
    <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
    <connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
    <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
    <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/>
    </process>
    </operator>
    <operator activated="true" class="text:wordlist_to_data" compatibility="8.1.000" expanded="true" height="82" name="WordList to Data" width="90" x="447" y="34"/>
    <operator activated="true" breakpoints="after" class="write_excel" compatibility="9.0.001" expanded="true" height="82" name="Write Excel" width="90" x="648" y="34">
    <parameter key="excel_file" value="C:\Users\PavithraRao\OneDrive - RapidMiner\Desktop-RMUS-PRAO\%{file_name_TEST}_word_list.xlsx"/>
    </operator>
    <connect from_op="Write Excel" from_port="through" to_port="out 1"/>
    </process>
    </operator>
    <operator activated="false" class="append" compatibility="9.0.001" expanded="true" height="68" name="Append" width="90" x="313" y="340"/>
    </process>
    </operator>
    </process>
    Cheers,
    User: "sgenzer"
    Altair Employee
    Accepted Answer
    hi @bazi66 - does this help? I disabled the Write Excel but you can obviously re-enable it if you want.
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="concurrency:loop_files" compatibility="9.0.001" expanded="true" height="82" name="Loop Files (2)" width="90" x="45" y="34">
    <parameter key="directory" value="/Users/genzerconsulting/Desktop/loop files"/>
    <parameter key="filter_type" value="regex"/>
    <parameter key="filter_by_regex" value=".*.pdf"/>
    <parameter key="enable_macros" value="true"/>
    <operator activated="true" class="text:read_document" compatibility="8.1.000" expanded="true" height="68" name="Read Document" width="90" x="45" y="34">
    </operator>
    <operator activated="true" class="text:process_documents" compatibility="8.1.000" expanded="true" height="103" name="Process Documents" width="90" x="179" y="34">
    </process>
    </operator>
    <operator activated="true" class="text:wordlist_to_data" compatibility="8.1.000" expanded="true" height="82" name="WordList to Data" width="90" x="313" y="34"/>
    <operator activated="true" class="rename" compatibility="9.0.001" expanded="true" height="82" name="Rename" width="90" x="447" y="34">
    <parameter key="old_name" value="in documents"/>
    <parameter key="new_name" value="in %{file_name}"/>
    <list key="rename_additional_attributes">
    <parameter key="total" value="total %{file_name}"/>
    </list>
    </operator>
    <connect from_op="WordList to Data" from_port="example set" to_op="Rename" to_port="example set input"/>
    <connect from_op="Rename" from_port="example set output" to_port="output 1"/>
    <portSpacing port="sink_output 1" spacing="0"/>
    <portSpacing port="sink_output 2" spacing="0"/>
    </process>
    </operator>
    <operator activated="false" class="write_excel" compatibility="9.0.001" expanded="true" height="82" name="Write Excel" width="90" x="313" y="34">
    </operator>
    <operator activated="true" class="subprocess" compatibility="9.0.001" expanded="true" height="82" name="Union Append" width="90" x="179" y="34">
    <operator activated="true" class="loop_collection" compatibility="9.0.001" expanded="true" height="82" name="Output (4)" width="90" x="45" y="34">
    <parameter key="set_iteration_macro" value="true"/>
    <operator activated="false" breakpoints="after" class="select" compatibility="9.0.001" expanded="true" height="68" name="Select (5)" width="90" x="112" y="34">
    <parameter key="index" value="%{iteration}"/>
    </operator>
    <operator activated="true" class="branch" compatibility="9.0.001" expanded="true" height="82" name="Branch (2)" width="90" x="313" y="34">
    <parameter key="condition_type" value="expression"/>
    <parameter key="expression" value="%{iteration}==1"/>
    <connect from_port="condition" to_port="input 1"/>
    <portSpacing port="source_condition" spacing="0"/>
    <portSpacing port="sink_input 1" spacing="0"/>
    <portSpacing port="sink_input 2" spacing="0"/>
    </process>
    <operator activated="true" class="recall" compatibility="9.0.001" expanded="true" height="68" name="Recall (5)" width="90" x="45" y="187">
    <parameter key="name" value="LoopData"/>
    </operator>
    <operator activated="true" class="union" compatibility="9.0.001" expanded="true" height="82" name="Union (2)" width="90" x="179" y="34"/>
    <connect from_port="condition" to_op="Union (2)" to_port="example set 1"/>
    <connect from_op="Recall (5)" from_port="result" to_op="Union (2)" to_port="example set 2"/>
    <connect from_op="Union (2)" from_port="union" to_port="input 1"/>
    </process>
    </operator>
    <operator activated="true" class="remember" compatibility="9.0.001" expanded="true" height="68" name="Remember (5)" width="90" x="581" y="34">
    </operator>
    <connect from_port="single" to_op="Branch (2)" to_port="condition"/>
    <connect from_op="Branch (2)" from_port="input 1" to_op="Remember (5)" to_port="store"/>
    <connect from_op="Remember (5)" from_port="stored" to_port="output 1"/>
    <portSpacing port="source_single" spacing="0"/>
    </process>
    </operator>
    <operator activated="true" class="select" compatibility="9.0.001" expanded="true" height="68" name="Select (6)" width="90" x="179" y="34">
    </operator>
    <connect from_port="in 1" to_op="Output (4)" to_port="collection"/>
    <connect from_op="Output (4)" from_port="output 1" to_op="Select (6)" to_port="collection"/>
    <connect from_op="Select (6)" from_port="selected" to_port="out 1"/>
    <portSpacing port="source_in 2" spacing="0"/>
    </process>
    </operator>
    <connect from_op="Loop Files (2)" from_port="output 1" to_op="Union Append" to_port="in 1"/>
    <connect from_op="Union Append" from_port="out 1" to_port="result 1"/>
    </process>
    </operator>
    </process>
    Scott
    [EDIT - ok I think you probably want to aggregate by word. I did this in this next process and also added case transformation and some stemming. Just made sense to me.]
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    </operator>
    <operator activated="true" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases" width="90" x="45" y="34"/>
    <operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="179" y="34"/>
    <operator activated="true" class="text:stem_porter" compatibility="8.1.000" expanded="true" height="68" name="Stem (Porter)" width="90" x="313" y="34"/>
    <connect from_port="document" to_op="Transform Cases" to_port="document"/>
    <connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/>
    <connect from_op="Tokenize" from_port="document" to_op="Stem (Porter)" to_port="document"/>
    <connect from_op="Stem (Porter)" from_port="document" to_port="document 1"/>
    </process>
    </operator>
    </list>
    </operator>
    </process>
    </operator>
    <operator activated="false" class="write_excel" compatibility="9.0.001" expanded="true" height="82" name="Write Excel" width="90" x="313" y="238">
    </operator>
    </operator>
    </process>
    </operator>
    </process>
    </operator>
    </operator>
    </process>
    </operator>
    </operator>
    </process>
    </operator>
    <operator activated="true" class="aggregate" compatibility="9.0.001" expanded="true" height="82" name="Aggregate" width="90" x="313" y="34">
    <parameter key="use_default_aggregation" value="true"/>
    <parameter key="default_aggregation_function" value="sum"/>
    <list key="aggregation_attributes"/>
    <parameter key="group_by_attributes" value="word"/>
    </operator>
    <connect from_op="Union Append" from_port="out 1" to_op="Aggregate" to_port="example set input"/>
    <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/>
    </process>
    </operator>
    </process>
    User: "bazi66"
    OP
    Hi,
    thank you very much for your help.
    @Pavithra_Rao your solution works very well, the multiple CSV files wouldn't have been an issue for me. Thanks!
    @sgenzer your solution works perfect and is more convenient for me. Thanks also for the additional process steps, the results look much better now.
    Cheers,
