Altair RISE
Nominate Yourself Now!
Meshing disc sector
User: "Andrea C."
Altair Community Member
Updated by Andrea C.
I am meshing a disc sector for which I need to have identical mesh on the radial surfaces. How can I project the mesh on one side to the other? It seems I can just project along a vector in rectangular coordinates.
1 - 9 of 91
    User: "Ben Buchanan"
    Altair Employee
    Updated by Ben Buchanan
    Would rotating the mesh work?
    User: "Andrea C."
    OP
    No, it won't because there are holes in it.
    Altair Employee
    Can you send a picture?
    Altair Employee
    Replicate option?
    User: "Andrea C."
    OP
    Replicate option?
    The disc has an not symmetric hole in the middle, so I'd like identical mesh on both the side so I can apply symmetry BC.
    User: "Andrea C."
    OP
    Additonal note. I'm still working with version 14.
    Altair Employee
    So you have a 2D mesh on the large side surface and you want it on the other side also to use to create a 3D mesh?  Maybe include the mesh in the picture.
    User: "Andrea C."
    OP
    Correct. I need identical meshes on both sides so I can apply paired displacements at nodes.
    Altair Employee
    Accepted Answer
    I don't know of a good way to project this.  You may be able to use morph but I think my approach would still be:
    Duplicate elements
    Rotate around center of disk (you probably know the angle from making the section)
    Assign nodes to surface
    Hope this helps.
