Writing an example set as xml
Hi,
I'd appreciate any help in writing an example set to xml.
I've tried the process below (as posted by Helge, http://rapid-i.com/rapidforum/index.php?topic=8256.0) but it doesn't combine the documents but instead produces only 1 record.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="6.0.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.008" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="6.0.008" expanded="true" height="60" name="Retrieve Golf" width="90" x="45" y="210">
<parameter key="repository_entry" value="//Samples/data/Golf"/>
</operator>
<operator activated="true" class="loop_examples" compatibility="6.0.008" expanded="true" height="94" name="Loop Examples" width="90" x="246" y="210">
<operator activated="true" class="loop_attributes" compatibility="6.0.008" expanded="true" height="94" name="Loop Attributes" width="90" x="246" y="120">
<operator activated="true" class="text:extract_document" compatibility="5.3.002" expanded="true" height="76" name="Extract Document" width="90" x="246" y="165">
<parameter key="attribute_name" value="%{loop_attribute}"/>
<parameter key="example_index" value="%{example}"/>
</operator>
<operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="CLose Tag (2)" width="90" x="246" y="615">
<parameter key="text" value="</%{loop_attribute}> "/>
</operator>
<operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="CLose Tag (3)" width="90" x="514" y="660">
</operator>
<operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Open Tag" width="90" x="246" y="75">
<parameter key="text" value=" <%{loop_attribute}>"/>
</operator>
<operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="CLose Tag" width="90" x="246" y="255">
</operator>
<operator activated="true" class="text:combine_documents" compatibility="5.3.002" expanded="true" height="112" name="Combine Documents" width="90" x="447" y="165"/>
<connect from_port="example set" to_op="Extract Document" to_port="example set"/>
<connect from_op="Extract Document" from_port="document" to_op="Combine Documents" to_port="documents 2"/>
<connect from_op="Open Tag" from_port="output" to_op="Combine Documents" to_port="documents 1"/>
<connect from_op="CLose Tag" from_port="output" to_op="Combine Documents" to_port="documents 3"/>
<connect from_op="Combine Documents" from_port="document" to_port="result 1"/>
<portSpacing port="source_example set" spacing="0"/>
<portSpacing port="sink_example set" spacing="0"/>
</process>
</operator>
<operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Close XML" width="90" x="246" y="255">
<parameter key="text" value="</data>"/>
</operator>
<operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Begin XML" width="90" x="246" y="30">
<parameter key="text" value="<?xml version="1.0" encoding="utf-8"?> <data> "/>
</operator>
<operator activated="true" class="text:combine_documents" compatibility="5.3.002" expanded="true" height="112" name="Combine Documents (2)" width="90" x="447" y="120"/>
<operator activated="true" class="text:write_document" compatibility="5.3.002" expanded="true" height="76" name="Write Document" width="90" x="581" y="120">
<parameter key="file" value="C:\Users\hhomburg\Documents\out_%{example}.xml"/>
</operator>
<connect from_port="example set" to_op="Loop Attributes" to_port="example set"/>
<connect from_op="Loop Attributes" from_port="result 1" to_op="Combine Documents (2)" to_port="documents 2"/>
<connect from_op="Close XML" from_port="output" to_op="Combine Documents (2)" to_port="documents 3"/>
<connect from_op="Begin XML" from_port="output" to_op="Combine Documents (2)" to_port="documents 1"/>
<connect from_op="Combine Documents (2)" from_port="document" to_op="Write Document" to_port="document"/>
<connect from_op="Write Document" from_port="document" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
</operator>
<connect from_op="Retrieve Golf" from_port="output" to_op="Loop Examples" to_port="example set"/>
<connect from_op="Loop Examples" from_port="output 1" to_port="result 1"/>
</process>
</operator>
</process>
Cheers
1 - 3 of
31
Hi,
I extended the process a bit and now I obtain an .xml file that I can read with the Read XML operator.
I hope it helps!
Regards,
Sebastian
