How to run Rapidminer Process from Java console application?
I built a process in Rapidminer Studio (classification with decision tree/neural net), I would like to load this process and run it with different datasets in a Java console application. I read about this here, but I didn't really found a great tutorial/documentation, how to do this, the basic things (load process, change properties, change the training model, ... ). Any advice would be helpful.
@Thomas_Ott that's not right.As long as it part of the open core you can do this. I think there is no explicit documentation on it though.
Easy way might be to use the CLI.
Best,
Martin
Thanks! These informations were really helpful.
RapidMiner.setExecutionMode(RapidMiner.ExecutionMode.COMMAND_LINE);
RapidMiner.init();
Process process = new Process(new File("/MyProcessFile.rmp"));
System.out.println(process.run());
Finally I wrote this, after that I got the result. Maybe it'll be useful for others.
hi !
i'm trying to do the same but i'm getting this exception. Im using springboot and maven, i also included rapidminer libraries as dependencies in pom.xml but still, it doesn't work
can anybody help me ?
thank you
<em class="error">The operator class 'jdbc_connectors:read_database' is unknown. Possibly you must install a plugin for operators of group 'jdbc_connectors'.</em>
2018-07-14 23:48:47.970 INFO 19264 --- [qtp411408557-27] com.rapidminer : The parameter 'define_connection' is unknown for operator 'Read Database (2)' (" dummy ")."
2018-07-14 23:48:47.971 INFO 19264 --- [qtp411408557-27] com.rapidminer : The parameter 'connection' is unknown for operator 'Read Database (2)' (" dummy ")."
2018-07-14 23:48:47.971 INFO 19264 --- [qtp411408557-27] com.rapidminer : The parameter 'database_system' is unknown for operator 'Read Database (2)' (" dummy ")."
2018-07-14 23:48:47.972 INFO 19264 --- [qtp411408557-27] com.rapidminer : The parameter 'define_query' is unknown for operator 'Read Database (2)' (" dummy ")."
2018-07-14 23:48:47.972 INFO 19264 --- [qtp411408557-27] com.rapidminer : The parameter 'query' is unknown for operator 'Read Database (2)' (" dummy ")."
2018-07-14 23:48:47.973 INFO 19264 --- [qtp411408557-27] com.rapidminer : The parameter 'query_file' is unknown for operator 'Read Database (2)' (" dummy ")."
2018-07-14 23:48:47.973 INFO 19264 --- [qtp411408557-27] com.rapidminer : The parameter 'use_default_schema' is unknown for operator 'Read Database (2)' (" dummy ")."
2018-07-14 23:48:47.973 INFO 19264 --- [qtp411408557-27] com.rapidminer : The parameter 'prepare_statement' is unknown for operator 'Read Database (2)' (" dummy ")."
2018-07-14 23:48:47.973 INFO 19264 --- [qtp411408557-27] com.rapidminer : The parameter 'parameters' of type enumeration is unknown for operator 'Read Database (2)' (" dummy ")."
2018-07-14 23:48:47.974 INFO 19264 --- [qtp411408557-27] com.rapidminer : The parameter 'datamanagement' is unknown for operator 'Read Database (2)' (" dummy ")."
2018-07-14 23:48:47.974 INFO 19264 --- [qtp411408557-27] com.rapidminer : The parameter 'data_management' is unknown for operator 'Read Database (2)' (" dummy ")."
2018-07-14 23:48:47.975 INFO 19264 --- [qtp411408557-27] com.rapidminer : <em class="error">The output port <var>output</var> is unknown at operator <var>Read Database (2)</var>.</em>
2018-07-14 23:48:47.980 INFO 19264 --- [qtp411408557-27] com.rapidminer.Process : No filename given for result file, using stdout for logging results!
2018-07-14 23:48:47.982 INFO 19264 --- [qtp411408557-27] com.rapidminer.Process : Process C:\Users\juasu\git\nubyte-backend-spring\src\main\resources\ModeloReglasAsociacionV5.rmp starts
excepcion
com.rapidminer.operator.UserError: The dummy operator Read Database (2) (replacing jdbc_connectors:read_database) cannot be executed.
at com.rapidminer.operator.DummyOperator.doWork(DummyOperator.java:94)
RapidMiner.init();
Your best bet is to use RapidMiner Server or getting an OEM license.
