Hypermesh 13.0 bug with Solid map?
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hi,
I have a problem with Hypermesh 13.0. Here're my environment:
  • Hyperwork 13.0 with all updates
  • OS : Windows 7 64bit professional SP1
  • User Profile : NASTRAN
  • Mesh Option: element order: second
  • 3D meshing method : solid map
When I ask for density=2, Hypermesh creates 4 element layers (see screenshot).
Hypermesh model is in attached ZIP file.
Anyone could confirm me this 'bug' ?
Thanks,
<?xml version="1.0" encoding="UTF-8"?>post-889-0-19065900-1425119805_thumb.png
Welcome!
Answers
  • Rahul_P1
    Rahul_P1
    Altair Employee
    edited March 2015
    I get only two layers, however I am not able to use the source hint and destination hint, I just select the solid and get the result
    <?xml version="1.0" encoding="UTF-8"?>post-4438-0-46372900-1425272517_thumb.pn
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2015
    @Rahul: thank you for your reply.
    Can you do 'Solid map' with only 'source hint' & Density ?
  • Rahul_P1
    Rahul_P1
    Altair Employee
    edited March 2015
    within the one volume panel , I don't think this is allowed, I get an error saying the solid needs to be selected.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2015
    I just done two tests with the same model and the same method:
    1. Hyperworks 13 without any update, Windows 7 64bit: Solid map with 'Source hint' and 'Density' => OK
    2. Hyperworks 13 with only 13.0.103_hotfix, Linux 64bit : Solid map with 'Source hint' and 'Density' => OK
    So I think the bug comes from the lastest update 'hwdesktop13.0.110'.
    My local Altair support just confirmed this bug.
    Thanks,
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2015
    This bug, found & reported by me, was fixed with 'hwdesktop13.0.111_hotfix' image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
Welcome!
Welcome!
