Storing Auto Model
After completing the auto model process, and opening the design view for the GBT model, i have two questions:
1. How to Store? Typically I would do this after the Cross Validation operator, but the CV operator is inside of the Optimize Parameters operator, so do i attach the Store operator there?
2. In the Results -> Explain Predictions view, there is no data. It is blank. I was hoping to view the actual vs. predicted data.
Thank You.
1 - 3 of
31
1 - 1 of
11
You can add the Store operator after the optimize operator (connected to the model output port of course).
As far as the problem with the Explain Predictions, I am not sure. You might want to post your process to troubleshoot.
