🎉Community Raffle - Win $25
Join and Win
JRIP Parameter Detalis
User: "mushi_pcr"
New Altair Community Member
Updated by Jocelyn
I need further details about the Jrip algorithem parameter which is shown below:
F (optional)
N (optional)
Set the minimal weights of instances within a split. (default 2.0)
O (optional)
Set the number of runs of optimizations. (Default: 2)
D (optional)
Set whether turn on the debug mode (Default: false)
Type: boolean
Default: false
S (optional)
The seed of randomization (Default: 1)
Type: real
Range: -∞ - +∞
Default: 1.0
E (optional)
Whether NOT check the error rate>=0.5 in stopping criteria (default: check)
Type: boolean
Default: false
P (optional)
Whether NOT use pruning (default: use pruning)
Type: boolean
Default: false
