I need further details about the Jrip algorithem parameter which is shown below:
F (optional)
Set the minimal weights of instances within a split. (default 2.0)
Set the number of runs of optimizations. (Default: 2)
hello @mushi_pcr - can I assume that you're referring to the Weka J-RIP operator?
Scott
yes
ok. Which parameters exactly do you need help with?
it will better you give breif and clear details of all parameter
