how can i calculate entropy and standard deviation of one numeric feature for each record?
New Altair Community Member
Updated by Jocelyn
hi
i am new in rapidminer and i want to calculate entropy and standard deviation of one feature for each record of example set... i cant find this operator.... how i can do it????
1 - 5 of
51
@ramzanzadeh72 I assume you are referring to Information theory. So there's a few ways to do it. There's an operator called Discretize by Entropy and there is are some weighting operators using Information Gain.
Also check out this thread: https://community.rapidminer.com/t5/RapidMiner-Studio-Forum/Information-gain-calculation/td-p/14572
hello @ramzanzadeh72 - welcome to the community. I'm confused with your question. How do you calculate the standard deviation of only one number? If you want to calculate the standard deviation of an entire column/feature, you can do this easily with the Aggregate operator.
Scott
