No Results from simulation
User: "Abhi05"
Altair Community Member
Updated by Abhi05
When I run my model, the solver starts to run but hangs up without showing any error or warning,
I just get to see the following output:
The amount of memory allocated for the run is 1000 MB.
This run will use in-core processing in the solver.
After this, nothing happens, neither can I kill the run nor abort it or pause it also, I cannot close the window.
In the top right corner, it shows,
Iteration: 0
Progress: 100%
Iteration progress: 0
