Altair RISE
Nominate Yourself Now!
How to insert text in multiple attributes (in the beginning)?
User: "ebayundso"
New Altair Community Member
Updated by Jocelyn
Hi all,
i try to add text to all my values in one attrtibute, for example my values of attributes are:
Up
Polo
Beetle
Tiguan
Touran
Caddy
Golf
Passat
an they should add "VW" in the beginning:
VW Up
VW Polo
VW Beetle
VW Tiguan
VW Touran
VW Caddy
VW Golf
VW Passat
Do you have a solution for my problem? :)
1 - 5 of 51
    User: "Thomas_Ott"
    I would use the Replace operator for that. You'd have to do a RegEx to select the word and then append it with VW.
    of the top of my head something like this (.*) to select it and replace it with VW $1
    User: "lionelderkrikor"
    Hi @ebayundso,
    I don't know if it is the optimal solution, but it works :
    <?xml version="1.0" encoding="UTF-8"?><process version="8.1.003">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.1.003" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="read_excel" compatibility="8.1.003" expanded="true" height="68" name="Read Excel" width="90" x="179" y="34">
    <parameter key="excel_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Replace_Values\Replace_values.xlsx"/>
    <parameter key="imported_cell_range" value="A1:A9"/>
    <parameter key="first_row_as_names" value="false"/>
    <list key="annotations">
    <parameter key="0" value="Name"/>
    </list>
    <list key="data_set_meta_data_information">
    <parameter key="0" value="Att1.true.polynominal.attribute"/>
    </list>
    </operator>
    <operator activated="true" class="replace" compatibility="8.1.003" expanded="true" height="82" name="Replace" width="90" x="313" y="34">
    <parameter key="attribute_filter_type" value="single"/>
    <parameter key="attribute" value="Att1"/>
    <parameter key="replace_what" value="(?&lt;![^ ])(?=[^ ])(?!VW )"/>
    <parameter key="replace_by" value="\VW "/>
    </operator>
    <connect from_op="Read Excel" from_port="output" to_op="Replace" to_port="example set input"/>
    <connect from_op="Replace" from_port="example set output" to_port="result 1"/>
    </process>
    </operator>
    </process>
    Regards,
    Lionel
    User: "ebayundso"
    OP
    Thomas_Ottthis adds a "VW" in the beginning but also in the end... :(
    User: "Telcontar120"
    Using "Generate Attributes" you can also create another attribute with the value VW (or other car manufacturers as needed) and then create a third attribute which concatenates the manufacturer and the model.
    User: "Edin_Klapic"
    Hi @ebayundso,
    In the Parameter replace what the RegEx characters ^ and $ have an additional meaning.
    If you use ^ as first character it means "Beginning". $ means "End"
    The RegEx would then be:
    Replace: ^(.*)$
    by: VW $1
    Happy Mining,
    Edin
