🎉Community Raffle - Win $25
Join and Win
association rules data preparation help needed
User: "piernik"
New Altair Community Member
Updated by Jocelyn
Hi all,
I am new to RapidMiner and need some help. I am working on basket analysis and found this dataset
http://www.sci.csueastbay.edu/~esuess/classes/Statistics_6620/Presentations/ml13/groceries.csv
but I struggle with data preparation. The attributes should be constructed from all possible item titles and each transaction should have either true or false in the right column. E.g I need to convert this:
1 milk pastry
2 milk sausage
Into this:
  milk pastry sausage
1 TRUE TRUE FALSE
2 TRUE FALSE TRUE
I will appreciate any help.
Regards
Rob
1 - 5 of 51
    User: "lionelderkrikor"
    Hi @piernik
    You had to add the attribute name of your list of grocery in the .CSV file (I named it "Att1" / See attached file)
    and here the process for the data preparation :
    <?xml version="1.0" encoding="UTF-8"?><process version="8.1.003">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.1.003" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="read_csv" compatibility="8.1.003" expanded="true" height="68" name="Read CSV" width="90" x="112" y="34">
    <parameter key="csv_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Data_Preparation\groceries.csv"/>
    <parameter key="column_separators" value=","/>
    <parameter key="first_row_as_names" value="false"/>
    <list key="annotations">
    <parameter key="0" value="Name"/>
    </list>
    <parameter key="encoding" value="windows-1252"/>
    <list key="data_set_meta_data_information">
    <parameter key="0" value="Att1.true.polynominal.attribute"/>
    </list>
    </operator>
    <operator activated="true" class="nominal_to_binominal" compatibility="8.1.003" expanded="true" height="103" name="Nominal to Binominal" width="90" x="313" y="34">
    <parameter key="attribute_filter_type" value="single"/>
    <parameter key="attribute" value="Att1"/>
    <parameter key="transform_binominal" value="true"/>
    <parameter key="use_underscore_in_name" value="true"/>
    </operator>
    <operator activated="false" class="rename_by_replacing" compatibility="8.1.003" expanded="true" height="82" name="Rename by Replacing" width="90" x="447" y="34">
    <parameter key="replace_what" value=".+\.Att1_($|\n)"/>
    </operator>
    <connect from_op="Read CSV" from_port="output" to_op="Nominal to Binominal" to_port="example set input"/>
    <connect from_op="Nominal to Binominal" from_port="example set output" to_port="result 1"/>
    </process>
    </operator>
    </process>
    I hope it helps,
    Regards,
    Lionel
    Hi again @piernik
    Here the process with the renamed attributes (ex : Att1_butter --> butter) :
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    </list>
    </list>
    </operator>
    </operator>
    <operator activated="true" class="rename_by_replacing" compatibility="8.1.003" expanded="true" height="82" name="Rename by Replacing" width="90" x="514" y="34">
    <parameter key="replace_what" value="\bAtt1_"/>
    </operator>
    <connect from_op="Nominal to Binominal" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/>
    <connect from_op="Rename by Replacing" from_port="example set output" to_port="result 1"/>
    </process>
    </operator>
    </process>
    Regards,
    Lionel
    User: "piernik"
    OP
    Hi Lionel,
    Many thanks for the solution. Your idea of renaming column is pretty smart! I did not know this operator.
    The solution works well if there is only one attribute. The source .csv file contains multiple transaction lines. I noticed that RapidMiner processes only the first one. For example, some transactions may look like this:
    1. milk, egg, sausage
    2. butter
    3. egg, sugar, cake, water
    When I read the csv file, RapidMiner sees only the first attribute:
    1. milk
    2. butter
    3. egg
    But this is not an issue. I have reformatted the file as a proper comma delimited and added the columns headers 'PurchaseLine01'... (see file attached) Now RapidMiner sees all the attributes.
    The problem is how to create a column for each item from all PurchaseLines. So for the example, there are three transactions below, where some customers purchased two, three or four products:
    PurchaseLine01 PurchaseLine02 PurchaseLine03 PurchaseLine04
    milk egg sausage
    butter  water
    egg sugar cake water
    The output should be:
      milk egg sausage butter sugar cake water
    1 TRUE TRUE TRUE FALSE FALSE FALSE FALSE
    2 FALSE FALSE FALSE TRUE FALSE FALSE TRUE
    3 FALSE TRUE FALSE FALSE TRUE TRUE TRUE
    I think it could be something along these lines:
    1. Create a list of all distinctive items from all transactions and purchase lines
    2. Using the above list, create a column for each product
    3. Map items with TRUE/FALSE depending on what was purchased in a given transaction
    I hope this makes sense.
    Many thanks
    Rob
    Hi @piernik,
    Unfortunately, I failed to achieve the transformation of your dataset with RapidMiner ' s native operators.
    So, I used a Python script :
    To execute this process, you have to install the Python environment on your computer and to install
    the Execute Python operator (from the MarketPlace).
    The process :
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="read_excel" compatibility="8.1.003" expanded="true" height="68" name="Read Excel" width="90" x="112" y="34">
    <parameter key="excel_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Data_Preparation\Purchases.xlsx"/>
    <parameter key="imported_cell_range" value="A1:D4"/>
    </list>
    <parameter key="0" value="PurchaseLine01.true.polynominal.attribute"/>
    <parameter key="1" value="PurchaseLine02.true.polynominal.attribute"/>
    <parameter key="2" value="PurchaseLine03.true.polynominal.attribute"/>
    <parameter key="3" value="PurchaseLine04.true.polynominal.attribute"/>
    </list>
    </operator>
    <operator activated="true" class="python_scripting:execute_python" compatibility="7.4.000" expanded="true" height="82" name="Execute Python" width="90" x="246" y="34">
    <parameter key="script" value="import pandas as pd&#10;import numpy as np&#10;&#10;# rm_main is a mandatory function, &#10;# the number of arguments has to be the number of input ports (can be none)&#10;&#10;&#10;def rm_main(data):&#10;&#10; def get_series(string): &#10; return (data == string).T.any() &#10;&#10; cols = np.unique(data.stack().values).tolist() &#10; data_2 = pd.DataFrame(columns=cols, index=range(len(data))) &#10; &#10; for col in cols: &#10; data_2[col] = get_series(col)&#10;&#10; &#10; return data_2"/>
    </operator>
    <connect from_op="Read Excel" from_port="output" to_op="Execute Python" to_port="input 1"/>
    <connect from_op="Execute Python" from_port="output 1" to_port="result 1"/>
    </process>
    </operator>
    </process>
    I hope it helps,
    Regards,
    Lionel
    NB : My intimate conviction is that this dataset transformation is possible with RapidMiner (without scripts), so if someone has an idea, I'll be curious to know it.
    User: "383742481"
    o,can you solve this problem now? Please tell me how to do this?thank U
