🎉Community Raffle - Win $25
Join and Win
Store Looped values
User: "christian_feise"
New Altair Community Member
Updated by Jocelyn
Hello community
I am running a Loop Values operator and want to store the table that is created for each attribute with a different name (preferably the name of the given attribute)
how do i do this?
thanks a lot
chris
1 - 3 of 31
    User: "SGolbert"
    Hi Christian,
    can you please post the process you are using? We will be able to help you if we know a bit more of what you are doing.
    Cheers,
    Sebastian
    OP
    <?xml version="1.0" encoding="UTF-8"?><process version="8.1.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.1.001" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="retrieve" compatibility="8.1.001" expanded="true" height="68" name="Retrieve datediffalle" width="90" x="45" y="34">
    <parameter key="repository_entry" value="//Local Repository/data/datediffalle"/>
    </operator>
    <operator activated="true" class="filter_examples" compatibility="8.1.001" expanded="true" height="103" name="Filter Examples (2)" width="90" x="179" y="34">
    <list key="filters_list"/>
    </operator>
    <operator activated="true" class="concurrency:loop_values" compatibility="8.1.001" expanded="true" height="82" name="Loop Values" width="90" x="380" y="34">
    <operator activated="true" class="filter_examples" compatibility="8.1.001" expanded="true" height="103" name="Filter Examples" width="90" x="112" y="34">
    </operator>
    <connect from_port="input 1" to_op="Filter Examples" to_port="example set input"/>
    <connect from_op="Filter Examples" from_port="example set output" to_port="output 1"/>
    <portSpacing port="source_input 2" spacing="0"/>
    <portSpacing port="sink_output 1" spacing="0"/>
    <portSpacing port="sink_output 2" spacing="0"/>
    </process>
    </operator>
    <connect from_op="Retrieve datediffalle" from_port="output" to_op="Filter Examples (2)" to_port="example set input"/>
    <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Loop Values" to_port="input 1"/>
    <connect from_op="Loop Values" from_port="output 1" to_port="result 1"/>
    </process>
    </operator>
    </process>
    Hello, This is the code i am using. i retrieve a datasheet, filter for one attribute and then want to store every example set that is created in the Loop values operator.
    thank you
    User: "sgenzer"
    Altair Employee
    Accepted Answer
    hi @christian_feise welcome to the community. I have your process on my computer. So after a quick inspection I see that your Filter Examples operators do not have any parameters; you need to put something there.
    As for merging the output (if that's indeed what you want), you just need to put either an Append operator (if all your data sets inside are exactly the same) or the Union Append building block (if they're not all exactly the same) after Loop Values. Then you can Store.
    Scott
