Error When Running the analysis with GPU CUDA Solver
Hello Community,
I get this error when I try to run the simulation with the GPU CUDA Solver (Attached Photo). I have run other analysis with the GPU Cuda Solver, but I never had get that error. Can anyone help me with that.
By the way, with which solver is better to run the analysis GPU or CPU. I have noticed that CPU solver takes more time to run the simulation, but I don´t know if the results gotten are more accurate.
Thank you for your time. I will appreciate all of your responses
