Altair RISE
Nominate Yourself Now!
"Python path no longer correct after upgrade to 8.1"
User: "kayman"
New Altair Community Member
Updated by Jocelyn
Hi, just finished upgrading from 7.5 to 8.1, and though most seems to be ok I can no longer use any of my processes that include python (which are unfortunatly most of them). The system can no longer find installed python modules etc. Is there some hidden thing to do to also ensure the job agents use the correct path? I have both 2.7 and 3.5 on my system and it seems to ignore the latter even that's the one used for the path. It also worked fine for RM 7x, no changes have been made apart from server upgrade.
All extensions are available in both the normal and agent folders.
1 - 1 of 11
    User: "kayman"
    OP
    Accepted Answer
    Nevermind, found out in the meantime that I had to add it to my container properties also. Everything is working fine again. Could be a good idea to have at least the basic properties assigned automatically to the default job agent.
