phase shift
Updated by Altair Forum User
Submitted by akowal on Thu, 05/17/2012 - 21:35
I'm trying to setup 6 signals, 3 are 120 degrees out of phase with one another, and the other 3 are 180 degrees out of phase with the first 3. Is it possible to achieve this, and still have the signal start at zero? See the attached file if still unsure what I'm trying to do.
1 - 3 of
31
Submitted by akowal on Wed, 05/23/2012 - 23:17.
is it possible to do the same with triangular waveforms, I tried using the same method but it outputs zero until the delay is over
Submitted by Anders89 on Thu, 05/24/2012 - 03:48.
Yes, but you need to have a negative offset to get a pure phase. A positive off set gives the dead time as you saw.
See attached file below.
Submitted by Anders89 on Fri, 05/18/2012 - 20:39.
I would use the Time Delay (phase) field of the sin block, and parameterize your frequency and period. See attached file.
