🎉Community Raffle - Win $25
Join and Win
Is there a way to make a geometry subject to gravity?
User: "Dylan Meiners"
Altair Community Member
Updated by Dylan Meiners
I have used the force controller gravity option but am noticing that it doesn't give a true gravity. Is there any other way to make a geometry move in this manner?
1 - 1 of 11
    User: "Stephen Cole"
    Altair Employee
    Updated by Stephen Cole
    hi Dylan,
    You should be able to select the 'include gravity in Force Calculation' tick box:
    Under the geometry section > Mass it best to ensure the mass is setup correctly.  EDEM will calculate it from the volume and density if it's a closed geometry but if it's an open shell you may have to set this yourself.
    Regards
    Stephen
