"Calculating average with missing values"
User: "iesnaola"
New Altair Community Member
Updated by Jocelyn
Hi everyone,
Having a Dataset like the following one:
row - Att1 - Att2 - Att3
(1)     5        7         5
(2)     6        8         9
(3)               7         6
(4)               7
I want to calculate the average so that result would be the following one:
row - Att1 - Att2 - Att3 - Average
(1)     5        7         5         5.6
(2)     6        8         9         7.6
(3)               7         6         6.5
(4)               7                    7
I am using operator Generate Attributes, with the following function:
avg(Att1, Att2, Att3)
However, when any of the rows has a missing value, I simply get a Missing Value as Average.
I would like to know how to solve this problem.
Thanks in advance
1 - 3 of 31
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    Hi,
    the generate aggregation operator is able to do it.
    Best,
    Martin
    User: "lionelderkrikor"
    Accepted Answer
    HI @iesnaola,
    You have to use the Generate Aggregation operator and check the parameter ignore missing
    Here the process :
    <?xml version="1.0" encoding="UTF-8"?><process version="8.0.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.0.001" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="read_excel" compatibility="8.0.001" expanded="true" height="68" name="Read Excel" width="90" x="112" y="34">
    <parameter key="excel_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Average_missing\Average_missing.xlsx"/>
    <parameter key="imported_cell_range" value="A1:C5"/>
    <parameter key="first_row_as_names" value="false"/>
    <list key="annotations">
    <parameter key="0" value="Name"/>
    </list>
    <list key="data_set_meta_data_information">
    <parameter key="0" value="Att1.true.integer.attribute"/>
    <parameter key="1" value="Att2.true.integer.attribute"/>
    <parameter key="2" value="Att3.true.integer.attribute"/>
    </list>
    </operator>
    <operator activated="true" class="generate_aggregation" compatibility="8.0.001" expanded="true" height="82" name="Generate Aggregation" width="90" x="447" y="34">
    <parameter key="attribute_name" value="average"/>
    <parameter key="aggregation_function" value="average"/>
    </operator>
    <connect from_op="Read Excel" from_port="output" to_op="Generate Aggregation" to_port="example set input"/>
    <connect from_op="Generate Aggregation" from_port="example set output" to_port="result 1"/>
    </process>
    </operator>
    </process>
    Regards,
    Lionel
    User: "iesnaola"
    OP
    Thanks! It worked :)
