🎉Community Raffle - Win $25
Join and Win
generate attribute based on multiple values
User: "khansaa0000"
New Altair Community Member
Updated by Jocelyn
 hi every body i am new in using rapidmier i wish i will find help here
i have 12 attributes which are representing the number of transaction per each month of the year i want to compere this value in order to show the curve is it increasing or decreasing
1 - 6 of 61
    User: "sgenzer"
    Altair Employee
    hello @khansaa0000 - very good to see you here. :)  Please reply with your data set attached (click the "Choose Files" button) and insert any XML process you have built so far using the </> code insert tool.
    Scott
    User: "Thomas_Ott"
    So this is pretty easy to visualize assuming your data is in this format:
    Month  Sales
    Jan      10000
    Feb      9000
    Mar      9500
    You can just go to the Charts tab and select the right line chart.
    User: "khansaa0000"
    OP
    no i have data about 800 customer this number of transaction per month like
    cust_id ,  number of transaction of January ,number of transaction of feb , .... til dec
    User: "khansaa0000"
    OP
     ok this my code
    <?xml version="1.0" encoding="UTF-8"?><process version="7.5.001">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="7.5.001" expanded="true" name="Process">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="2001"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value=""/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="SYSTEM"/>
        <process expanded="true">
          <operator activated="true" class="read_csv" compatibility="7.5.001" expanded="true" height="68" name="Read CSV" width="90" x="45" y="34">
            <parameter key="csv_file" value="C:\Users\Khansaa\Desktop\month_transaction.csv"/>
            <parameter key="column_separators" value=","/>
            <parameter key="trim_lines" value="false"/>
            <parameter key="use_quotes" value="true"/>
            <parameter key="quotes_character" value="&quot;"/>
            <parameter key="escape_character" value="\"/>
            <parameter key="skip_comments" value="false"/>
            <parameter key="comment_characters" value="#"/>
            <parameter key="parse_numbers" value="true"/>
            <parameter key="decimal_character" value="."/>
            <parameter key="grouped_digits" value="false"/>
            <parameter key="grouping_character" value=","/>
            <parameter key="date_format" value=""/>
            <parameter key="first_row_as_names" value="false"/>
            <list key="annotations">
              <parameter key="0" value="Name"/>
            </list>
            <parameter key="time_zone" value="SYSTEM"/>
            <parameter key="locale" value="English (United States)"/>
            <parameter key="encoding" value="windows-1252"/>
            <list key="data_set_meta_data_information">
              <parameter key="0" value="cus_id.true.integer.attribute"/>
              <parameter key="1" value="num_of_tran_jan.true.integer.attribute"/>
              <parameter key="2" value="num_of_feb.true.integer.attribute"/>
              <parameter key="3" value="num_of_tran_mar.true.integer.attribute"/>
              <parameter key="4" value="num_of_tran_apr.true.integer.attribute"/>
              <parameter key="5" value="num_of_tran_may.true.integer.attribute"/>
              <parameter key="6" value="num_of_tran_jun.true.integer.attribute"/>
              <parameter key="7" value="num_of_tran_jul.true.integer.attribute"/>
              <parameter key="8" value="num_of_tran_aug.true.integer.attribute"/>
              <parameter key="9" value="num_of_tran_sep.true.integer.attribute"/>
              <parameter key="10" value="num_of_tran_oct.true.integer.attribute"/>
              <parameter key="11" value="num_of_tran_no.true.integer.attribute"/>
              <parameter key="12" value="num_of_tran_dec.true.integer.attribute"/>
            </list>
            <parameter key="read_not_matching_values_as_missings" value="true"/>
            <parameter key="datamanagement" value="double_array"/>
            <parameter key="data_management" value="auto"/>
          </operator>
          <operator activated="true" class="nominal_to_numerical" compatibility="7.5.001" expanded="true" height="103" name="Nominal to Numerical" width="90" x="179" y="34">
            <parameter key="return_preprocessing_model" value="false"/>
            <parameter key="create_view" value="false"/>
            <parameter key="attribute_filter_type" value="subset"/>
            <parameter key="attribute" value=""/>
            <parameter key="attributes" value="acc_type|activity|stu"/>
            <parameter key="use_except_expression" value="false"/>
            <parameter key="value_type" value="nominal"/>
            <parameter key="use_value_type_exception" value="false"/>
            <parameter key="except_value_type" value="file_path"/>
            <parameter key="block_type" value="single_value"/>
            <parameter key="use_block_type_exception" value="false"/>
            <parameter key="except_block_type" value="single_value"/>
            <parameter key="invert_selection" value="false"/>
            <parameter key="include_special_attributes" value="false"/>
            <parameter key="coding_type" value="unique integers"/>
            <parameter key="use_comparison_groups" value="false"/>
            <list key="comparison_groups"/>
            <parameter key="unexpected_value_handling" value="all 0 and warning"/>
            <parameter key="use_underscore_in_name" value="false"/>
          </operator>
          <operator activated="true" class="select_attributes" compatibility="7.5.001" expanded="true" height="82" name="Select Attributes" width="90" x="313" y="85">
            <parameter key="attributes" value="cust_id||sum_in_money|sum_of_out_money|num_of_tran_jun|num_of_tran_mar|num_of_tran_dec|num_of_tran_apr|cus_id|num_of_feb|num_of_tran_sep|num_of_tran_oct|num_of_tran_no|num_of_tran_may|num_of_tran_jul|num_of_tran_jan|num_of_tran_aug"/>
            <parameter key="value_type" value="attribute_value"/>
            <parameter key="except_value_type" value="time"/>
            <parameter key="block_type" value="attribute_block"/>
            <parameter key="except_block_type" value="value_matrix_row_start"/>
          </operator>
          <operator activated="true" class="generate_attributes" compatibility="7.5.001" expanded="true" height="82" name="Generate Attributes" width="90" x="447" y="85">
            <list key="function_descriptions">
              <parameter key="Curve" value="if(num_of_tran_jul&gt;num_of_feb,&quot;Curve&quot;,&quot;Decreases&quot;)&#10;if(num_of_tran_jul&lt;num_of_feb,&quot;Curve&quot;,&quot;Increases&quot;)"/>
            </list>
            <parameter key="keep_all" value="true"/>
          </operator>
          <connect from_op="Read CSV" from_port="output" to_op="Nominal to Numerical" to_port="example set input"/>
          <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
          <connect from_op="Select Attributes" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
          <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
    User: "sgenzer"
    Altair Employee
    Accepted Answer
    ok hello again @khansaa0000 - I think this will help.  But before you use this, please upgrade to RapidMiner 8.
    <?xml version="1.0" encoding="UTF-8"?><process version="8.0.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.0.001" expanded="true" name="Process">
    <operator activated="true" class="read_csv" compatibility="8.0.001" expanded="true" height="68" name="Read CSV" width="90" x="45" y="34">
    <parameter key="csv_file" value="/Users/genzerconsulting/Desktop/month_transaction - Copy.csv"/>
    </list>
    <parameter key="0" value="cus_id.true.polynominal.attribute"/>
    </list>
    </operator>
    <operator activated="true" class="nominal_to_numerical" compatibility="8.0.001" expanded="true" height="103" name="Nominal to Numerical" width="90" x="179" y="34">
    </operator>
    <operator activated="true" class="select_attributes" compatibility="8.0.001" expanded="true" height="82" name="Select Attributes" width="90" x="313" y="85">
    </operator>
    <operator activated="true" class="generate_attributes" compatibility="8.0.001" expanded="true" height="82" name="Generate Attributes" width="90" x="447" y="85">
    <parameter key="Curve" value="if(num_of_tran_jul&gt;num_of_feb,&quot;Curve Decreases&quot;,&#10;if(num_of_tran_jul&lt;num_of_feb,&quot;Curve Increases&quot;,&quot;No change&quot;))"/>
    </list>
    </operator>
    </process>
    </operator>
    </process>
    Scott
    User: "khansaa0000"
    OP
