non-mappable(2) Solid map
Janeiro
Janeiro Altair Community Member
edited October 2020 in Community Q&A
Hi, i am trying to use the solid map feature to create a 3d mesh but there is an error that keeps showing up 'non-mappable(2):along-faces form 3 loops. need 9'. I have googled but have not found answers to my issue. I dont know what else to do appreciate any help.
I will attach my .hm file
Thank you
Welcome!
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2020
    hi,
    not sure if you are familiar to HM hex meshing.
    I suggest you to take a look at this video as a reference.
    You basically need to slice your solid in small mappable regions to get a full hex mesh.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.e44a6830e2e1995969d34cfa449fc809.png
    You need to activate the 'mappable' visualization, and slide your solid until you get all the solids green or yellow..
  • Janeiro
    edited June 2020
    YES, i am a complete newbie on this software my teacher gave us this task with no orientation no whatsoever :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />
    Thank you very much!!
  • Janeiro
    edited June 2020
    Hey again i have watched that video and other one similar and one thing that i cant understand is where to split my piece (the ones in the videos are always obvious) and when i do slice my piece in some place and proceed to create a 2d mesh when i try to create the solid map i get the same error with different numbers, even when i work on tiny segments of the part, idk if that helps or not but i tried bigger and smaller segments and i get the same error. ex: 'non-mappable(2):along-faces form 0 loops. need 1' or 'non-mappable(2):along-faces form 1 loops. need 2'. I dont know where these values come from... On the videos its always nice parts /:
    Thank you
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited June 2020
    @Janeiro: for your model, you can begin with 2D mesh (see my picture) and then build 3D mesh by 'drag'. It's so simple!
    <?xml version="1.0" encoding="UTF-8"?>surfaces.thumb.png.42449ed9b721f65ee736df78a38c173e.png
  • Janeiro
    edited June 2020
    Hey I tried to drag but what i got was not a mesh of the whole solid :/
    How do I mesh the whole solid with the 2d mesh i original have created? (i know theres a way cause others have done it)
    Am using drag the wrong way?
    Thanks
  • QuyNguyenDai
    edited June 2020
    Have a look at 2D mesh within '^Surf_1'  & '^Surf_2' and you will understand:
    HM model:
  • Janeiro
    edited June 2020
    Hey thank you so much guys i was able to do it with your help!!
Welcome!
Welcome!
