Load Collector : Card image
User: "Byshel"
Altair Community Member
Updated by Byshel
Hello,
I am a beginner on Hypermesh, I use the V12 version. I would like to do a non-linear calculation, but I don't have the NLOUT and CNTSTB load collectors.
I know that it is from V14 that these load collectors appear.
I would like to know if there is not a workaround or other equivalent charge collectors with the V12.
I would also like to know if it is possible to have the list of all load collectors with their description.
Thank you.
1 - 6 of 61
    User: "FaroukM"
    Updated by FaroukM
    Did you check param ?
    User: "Byshel"
    OP
    Updated by Byshel
    Hello,
    How do you go about checking this out?
    Thank.
    User: "FaroukM"
    Updated by FaroukM
    Hello,
    Thank.
    Analyse -> Control cards -> Param ?
    User: "Byshel"
    OP
    Updated by Byshel
    J'ai effectué l'analyse mais il y a un problème. je ne comprends pas le problème
    J'ai joint le fichier
    Remercier
    User: "Byshel"
    OP
    Updated by Byshel
    J'
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    Byshel,
    there was no support of these cards back in OS12. So you won't be able to use them.
    There's no equivalent for NLOUT.
    For CNTSTB there is PARAM,EXPERTNL,CNTSTB
    You can order for free the new HW student versions from Altair University with all the new features.
    12.0 is very outdated.
