specify the conclusion attribute for w-apriori algorithm with rapidminer
Hi,
I would like to find association rules in a dataset using rapidminer by applying the wapriori algorithm. I would like to have on the right side of rules a specific attribute.
For example, I have a dataset including attributes A, B and C. I would like to have C as a conclusion like:
if A, B then C/
if B then C
how can I force the wapriori algorithm to express a specific attribute as a result? how can I set this in rapidminer ? thanks
in my example, I want to conclude the influence of age, level and speciality on the category of the course in which a student is enrolled.
age = 25, Specialty = computing, level = license -> category = computing
age = 45, specialty = management, level = master -> category = computing
age=35, speciality=economyfiance, level=phd -> category=management....
so I want to have the course category as the result of the rule.
in my process, I have a first operator to extract the data from the MySQL database (age, level, speciality and category) then a numerical to binominal operator and finally the w-apriori operator.
Hi again @asmahassani08
Here I propose some response elements :
1. Given the description of your study, have you try the FP-Growth operator associated to Create Association Rules operator like this :
After executing the process, you go to the results panel, go to the Association rules tag et here you can filter your results by conclusion.
It looks like that :
2.An other way : have you try the Decision tree operator and/or the Linear Discriminant Analysis instead of
w-apriori operator ? Maybe these models can answer to your need...
3.if 1. and 2. don't answer to your need, can you share your dataset :
a. Insert a Write Excel operator after your extracting SQL operator
b. Set a path where the excel file will be saved.
c. Share this file by clicking on Sélect. files in this reply page :
Regards,
Lionel
@lionelderkrikor has some excellent suggestions here. I'll reinforce what he has noted, which is that typically with association rules you are not trying to "force" any particular outcome. You may be better off taking the outcome you are interested and using "Set Role" to turn it into a label, and then you can use traditional supervised learning algorithms to generate predictive models to see relationships specifically to your outcome of interest ("C"). You could even reformaulte your possible outcomes into a binominal (all outcomes are either "C" or "not "C") and that will open up an even wider range of predictive techniques for you to use.
Hi @asmahassani08,
Can you share your process and your entry example set, please ?
thanks you,
Regards,
Lionel
