🎉Community Raffle - Win $25
Join and Win
"How to get a Word list from select by weights operator?"
User: "hatem_alhasani"
New Altair Community Member
Updated by Jocelyn
hi guys,
i built model for sentiment analysis, i used Weight by Correlation and Select by Weights operations in my model.
i training my model with dataset of 1950 rows. i want to test my model with 3000 rows using apply model with wordlist generated from select by Weights not from wordlist that generated from process document from data operator.
my question how to get Word list from select by weights? Is there any macro or script do that?
My process
<?xml version="1.0" encoding="UTF-8"?><process version="7.6.001">
<operator activated="true" class="retrieve" compatibility="7.6.001" expanded="true" height="68" name="Retrieve Historical Sentiments" width="90" x="45" y="187">
<parameter key="repository_entry" value="//Samples/Templates/Sentiment Analysis/Historical Sentiments"/>
</operator>
</process>
<operator activated="true" class="set_role" compatibility="7.6.001" expanded="true" height="82" name="Set Role" width="90" x="179" y="187">
<parameter key="attribute_name" value="Sentiment"/>
<parameter key="target_role" value="label"/>
<list key="set_additional_roles"/>
</operator>
</process>
<operator activated="true" class="nominal_to_text" compatibility="7.6.001" expanded="true" height="82" name="Nominal to Text" width="90" x="313" y="187">
<parameter key="attribute_filter_type" value="all"/>
<parameter key="attribute" value=""/>
<parameter key="attributes" value=""/>
<parameter key="use_except_expression" value="false"/>
<parameter key="value_type" value="nominal"/>
<parameter key="use_value_type_exception" value="false"/>
<parameter key="except_value_type" value="file_path"/>
<parameter key="block_type" value="single_value"/>
<parameter key="use_block_type_exception" value="false"/>
<parameter key="except_block_type" value="single_value"/>
<parameter key="invert_selection" value="false"/>
<parameter key="include_special_attributes" value="false"/>
</operator>
</process>
<operator activated="true" class="text:process_document_from_data" compatibility="7.5.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="447" y="187">
<parameter key="create_word_vector" value="true"/>
<parameter key="vector_creation" value="TF-IDF"/>
<parameter key="add_meta_information" value="true"/>
<parameter key="keep_text" value="true"/>
<parameter key="prune_method" value="none"/>
<parameter key="prune_below_percent" value="3.0"/>
<parameter key="prune_above_percent" value="30.0"/>
<parameter key="prune_below_rank" value="0.05"/>
<parameter key="prune_above_rank" value="0.95"/>
<parameter key="datamanagement" value="double_sparse_array"/>
<parameter key="data_management" value="auto"/>
<parameter key="select_attributes_and_weights" value="false"/>
<list key="specify_weights"/>
<process expanded="true">
<operator activated="true" class="text:tokenize" compatibility="7.5.000" expanded="true" height="68" name="Tokenize" width="90" x="45" y="30">
<parameter key="mode" value="non letters"/>
<parameter key="characters" value=".:"/>
<parameter key="language" value="English"/>
<parameter key="max_token_length" value="3"/>
</operator>
<operator activated="true" class="text:transform_cases" compatibility="7.5.000" expanded="true" height="68" name="Transform Cases" width="90" x="246" y="34">
<parameter key="transform_to" value="lower case"/>
</operator>
<operator activated="true" class="text:filter_stopwords_english" compatibility="7.5.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="380" y="30"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
</process>
<operator activated="true" class="weight_by_correlation" compatibility="7.6.001" expanded="true" height="82" name="Weight by Correlation" width="90" x="581" y="187">
<parameter key="normalize_weights" value="false"/>
<parameter key="sort_weights" value="true"/>
<parameter key="sort_direction" value="ascending"/>
<parameter key="squared_correlation" value="false"/>
</operator>
</process>
<operator activated="true" class="select_by_weights" compatibility="7.6.001" expanded="true" height="103" name="Select by Weights" width="90" x="715" y="187">
<parameter key="weight_relation" value="top p%"/>
<parameter key="weight" value="1.0"/>
<parameter key="k" value="1000"/>
<parameter key="p" value="0.5"/>
<parameter key="deselect_unknown" value="true"/>
<parameter key="use_absolute_weights" value="true"/>
</operator>
</process>
<operator activated="true" class="concurrency:cross_validation" compatibility="7.6.001" expanded="true" height="145" name="Cross Validation" width="90" x="983" y="187">
<parameter key="split_on_batch_attribute" value="false"/>
<parameter key="leave_one_out" value="false"/>
<parameter key="number_of_folds" value="10"/>
<parameter key="sampling_type" value="automatic"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<parameter key="enable_parallel_execution" value="true"/>
<operator activated="true" class="support_vector_machine" compatibility="7.6.001" expanded="true" height="124" name="SVM" width="90" x="179" y="34">
<parameter key="kernel_type" value="dot"/>
<parameter key="kernel_gamma" value="1.0"/>
<parameter key="kernel_sigma1" value="1.0"/>
<parameter key="kernel_sigma2" value="0.0"/>
<parameter key="kernel_sigma3" value="2.0"/>
<parameter key="kernel_shift" value="1.0"/>
<parameter key="kernel_degree" value="2.0"/>
<parameter key="kernel_a" value="1.0"/>
<parameter key="kernel_b" value="0.0"/>
<parameter key="kernel_cache" value="200"/>
<parameter key="C" value="0.0"/>
<parameter key="convergence_epsilon" value="0.001"/>
<parameter key="max_iterations" value="100000"/>
<parameter key="scale" value="true"/>
<parameter key="calculate_weights" value="true"/>
<parameter key="return_optimization_performance" value="true"/>
<parameter key="L_pos" value="1.0"/>
<parameter key="L_neg" value="1.0"/>
<parameter key="epsilon" value="0.0"/>
<parameter key="epsilon_plus" value="0.0"/>
<parameter key="epsilon_minus" value="0.0"/>
<parameter key="balance_cost" value="false"/>
<parameter key="quadratic_loss_pos" value="false"/>
<parameter key="quadratic_loss_neg" value="false"/>
<parameter key="estimate_performance" value="false"/>
</operator>
<connect from_port="training set" to_op="SVM" to_port="training set"/>
<connect from_op="SVM" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
<portSpacing port="sink_model" spacing="0"/>
<portSpacing port="sink_through 1" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="7.6.001" expanded="true" height="82" name="Apply Model" width="90" x="112" y="34">
<parameter key="create_view" value="false"/>
</operator>
<operator activated="true" class="performance_binominal_classification" compatibility="7.6.001" expanded="true" height="82" name="Performance" width="90" x="313" y="34">
<parameter key="main_criterion" value="first"/>
<parameter key="accuracy" value="true"/>
<parameter key="classification_error" value="false"/>
<parameter key="kappa" value="false"/>
<parameter key="AUC (optimistic)" value="false"/>
<parameter key="AUC" value="false"/>
<parameter key="AUC (pessimistic)" value="false"/>
<parameter key="precision" value="false"/>
<parameter key="recall" value="false"/>
<parameter key="lift" value="false"/>
<parameter key="fallout" value="false"/>
<parameter key="f_measure" value="false"/>
<parameter key="false_positive" value="false"/>
<parameter key="false_negative" value="false"/>
<parameter key="true_positive" value="false"/>
<parameter key="true_negative" value="false"/>
<parameter key="sensitivity" value="false"/>
<parameter key="specificity" value="false"/>
<parameter key="youden" value="false"/>
<parameter key="positive_predictive_value" value="false"/>
<parameter key="negative_predictive_value" value="false"/>
<parameter key="psep" value="false"/>
<parameter key="skip_undefined_labels" value="true"/>
<parameter key="use_example_weights" value="true"/>
</operator>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="performance 1"/>
<portSpacing port="source_model" spacing="0"/>
<portSpacing port="source_test set" spacing="0"/>
<portSpacing port="source_through 1" spacing="0"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
</process>
</operator>
</process>
<operator activated="true" class="text:create_document" compatibility="7.5.000" expanded="true" height="68" name="Create Document" width="90" x="313" y="442">
<parameter key="text" value="Watching the movie , i vowed to subtract half a star from the review because the filmmakers &#10;included a saccharine syrup , cute 'n cuddly, computer-generated monkey. If the monkey died,&#10;the movie got an extra half star. Alas, the monkey showed up at the end , unharmed , to the &#10;wet sickly sound of gagging and rolling eyeballs . what that means is that lost in space &#10;actually deserved 2 stars . that's pretty generous , considering the movie's camp lacked &#10;any hint of tongue in cheek . when will robinson ( jack johnson ) teaches his pet robot &#10;about friendship , you are actually supposed to buy it . so why such a seemingly high rating?&#10; there are a few reasons that made me unable to throw away the experience with the garbage . &#10;Nobody in the country enjoyed the movie as much as my audience did &#10;( and i don't necessarily mean that in a good way ) . &#10;This is overlaid on a cool jumpy credit sequence with interesting distorted clips from &#10;the movie . but if that's the best part of the movie , i can't in good conscience recommend it."/>
<parameter key="add label" value="false"/>
<parameter key="label_type" value="nominal"/>
</operator>
</process>
<operator activated="true" class="text:process_documents" compatibility="7.5.000" expanded="true" height="103" name="Process Documents" width="90" x="581" y="442">
<operator activated="true" class="text:tokenize" compatibility="7.5.000" expanded="true" height="68" name="Tokenize (2)" width="90" x="112" y="34">
</operator>
<operator activated="true" class="text:transform_cases" compatibility="7.5.000" expanded="true" height="68" name="Transform Cases (2)" width="90" x="246" y="34">
</operator>
<operator activated="true" class="text:filter_stopwords_english" compatibility="7.5.000" expanded="true" height="68" name="Filter Stopwords (2)" width="90" x="380" y="30"/>
<connect from_port="document" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/>
<connect from_op="Transform Cases (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/>
<connect from_op="Filter Stopwords (2)" from_port="document" to_port="document 1"/>
</process>
</operator>
</process>
<operator activated="true" class="apply_model" compatibility="7.6.001" expanded="true" height="82" name="Apply Model (2)" width="90" x="1050" y="442">
</operator>
</process>
could you please help me to solve my problem?
regards,
1 - 6 of 61
    Hi,
    have a look at this article, that should do it: https://community.rapidminer.com/t5/RapidMiner-Studio-Knowledge-Base/Text-Mining-and-the-Word-List/ta-p/31723
    If not - have a look a look on Data to Weights. It creates a weight vector which might help you.
    Best,
    Martin
    OP
    thanks for your reply,
    first solution i mention about it in my question, it gives all words but i want sub list generate form exp of operator select by weight.
    and second solution Weights to Data it gives all  words same as wor of operator processing, also there is no operator convert to Word list
    from Data or weight or any thing.
    i want red box operator, macro or script convert exp set to word list or regular attribute Names  to word list.
    thanks, i am appreciated it.
    Hi,
    i think you need to combine the two things. Use the wordlist generated in the upper stream for the lower and use the select by Weights in the lower and the upper on the same weights.
    By the way, maybe you can ignore the second step. additional attributes are no problem while applying a learner. They will just get ignored.
    ~Martin
    OP
    when  i use select by weight in lower i get new features not equal training features, i need to get the traing features because i get less accuracy when i take all words.
    User: "Thomas_Ott"
    So you're going to need two new Process Documents from Data operators. After the Select by Weights operator put another Process Documents from Data operator and then ger rid of the Process  Documents operator in the lower branch. Replace it with a copy of the new Doc from Data operator. Connect the Wordlist outputs together. Should work then.
    OP
    i try your solution. i got the all features not training features
