🎉Community Raffle - Win $25
Join and Win
How to use optistruct for optimization
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi
I am new to FEM and just started using Hypermesh and its solvers. I realized that radioss and optistruct are basically the same but optistruct is also used for optimization. How exactly is a model optimized using optistruct and what optimization are we talking about. Any help will be appreciated
Thanks
Bharat
1 - 1 of 11
    Altair Employee
    OP
    Hi
    Thanks
    Bharat
    maybe if you could check the tutorials you will see how it works. basically you define some optimization targets and it solves the analysis several times to match those design targets, when it matches it stops solving and then you can evaluate the results with those desing targets. e.g. changing some normal modes through optimizing the mass.
