Average value and SD of attributes
User: "jean_claude_van"
New Altair Community Member
Updated by Jocelyn
Hello
I have a dataset in which I would like
i) to select automatically all the attributes having a name starting by letter C,
ii) then calculate the average value and standard deviation of the values of each attribute,
ii) get a final table with the name of the attributes and their average values and standard deviations.
Do you now operators I could use for that. I spent the afternoon without any success.
Jean Claude
1 - 2 of 21
    Hi,
    you can use Select Attributes with regular expression C.+
    Afterwards, you use Aggregate and activate the "default aggregation" which uses all attributes.
    Best,
    Martin
    User: "Telcontar120"
    Or you can use "Loop Attributes" and do a similar Aggregate operation inside the loop and then feed the results out to a dataset that you append together at the end.
