Value Export via Script for Incremental Distance
User: "juliuus_"
Altair Community Member
Updated by juliuus_
Hey,
I´m trying to create measures via tcl Script and export the values into a variable using GetValuellist.
Creating the measure works fine but the export of the result into a variable does not work. By using a messagebox I´m testing the output but it´s always empty.
Can somebody help me or find my mistake in the code?
Thank You!
1 - 1 of 11
    User: "Nagahashi Kouta"
    Updated by Nagahashi Kouta
    Hi,
    I have checked your script and found no error.
    Please confirm the node id you used in your script if they are valid in your result file.
    Please provide more information.
