LAW36 material curve assignment? [SOLVED]
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
In the RD-xxxx tutorials the stress-strain curve is assigned to fct_ID1, but I cannot find it in my Hypermesh. There is a curve assignment field under fct_ID_E, and one more field under the NFunc. If I assign it for fct_ID_E, RADIOSS gives an error that stress should decrease as plastic strain increases. If I assign to the field under NFunc, it also needs scale and EPS_DOT.
1. What are these two parameters?.
2. Eventually, where do I provide the curve?
3. Also, after creating the material, is there a way to view the true stress - strain curve just to confirm that RADIOSS interprets it correctly? I also tried the Johnson Cook material model but the results were way wrong (strain of >200% when the fail strain is 8%). So I just want to make sure the fields I am entering have correct interpretation by checking with the total stress strain curve.
1 - 9 of 91
    Altair Employee
    OP
    HI,
    Maybe you should scroll down a lil bit when you edit the material card.
    Altair Employee
    OP
    What you see is different from what I see. Anyway that is a bug.
    Altair Employee
    OP
    Hello Bongris,
    So, I was using an older version of HW here. Sorry for the confusion.
    Click the N_func and input 1. This will open a tab right below to refer the curve.
    Altair Employee
    OP
    Yeah that works for me! Thanks! Can you tell me what is the meaning of scale and EPS_DOT (is this strain rate for the stress-strain curve?)? The stress-strain curve is all that matters, so does RADIOSS calculate different stresses than the curve using the strain rate at that stage and then extrapolating using some theory?
    Altair Employee
    OP
    Prakash can you please tell me what is scale and EPS_DOT for the curve function?
    User: "gopal_rathore"
    Altair Community Member
    Updated by gopal_rathore
    Hi,
    This refers to the strain rate which is usually obtained form the testing data. Consider a tensile test of specimen, the rate at which it is displaced during the test is referred to as the EPS_DOT. In hypermesh, we can provide different values of the same along with the corresponding curves. Please find the attached image and for more details go the help content of MAT 36.
    Altair Employee
    OP
    Thanks for your reply Gopal!
    I wanted ask how RADIOSS uses the strain rate value?
    For example, if the curve is with a rate 0.1 per second, how does this value get used in any way?
    If the simulation has strain rate of 1 per second, will RADIOSS use a different stress-strain curve than the input?
    The user guide is not at all detailed, it only gives one liner definitions.
    Altair Employee
    OP
    Can someone please answer my question?
    Altair Employee
    OP
    Can you check the law characterization document in help menu where Elasto-plastic material law characterization in RADIOSS is explained.
