text mining using in execute python
User: "hmhsing"
Altair Community Member
Updated by Jocelyn
I hope to input a text file into Execute Python and do word segmentation. The python scripts is as following.  The result shows parsing failed, can anyone give me some suggestion? Thanks!
import pandas
import jieba
import csv
def rm_main():
    ff = open("C:/Users/user/Desktop/speech.txt").read()
    seglist = jieba.cut(ff, cut_all=False)
f = open("text.csv","w")
w = csv.writer(f)
w.writerows(seglist)
f.close()
1 - 3 of 31
    Hi,
    please have a look into the log window. There should be more information on the error.
    Best,
    Martin
    User: "hmhsing"
    OP
    The error message is:
    The script could not be parsed. Please check your Python script:ModuleNotFoundError:No module named 'jieba'
    I have already installed jieba package, and similar coding works in Python.
    Thanks!
    User: "Thomas_Ott"
    New Altair Community Member
    Accepted Answer
    Are you working in a Windows environment? If so then you Pandas and your Jeiba module need to be installed under an Anaconda distribution. Verify that.
