Reading multiples text files from a folder and converting them to an exampleset ?
I have a folder that contains multiple text files. So how can we read the content of each file and use them as a row in the exampleset.
for ex :
for a folder with 5 text files the exampleset will look like.
| Row | TextContent |
1 | contents of fille1
2 | contents of fille2
3 | contents of fille3
4 | contents of fille4
5 | contents of fille5
I'm having trouble with the above process since it only picks up the first line of every documents. The files are emails in .txt format. How can I extract the whole body of the texts?
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.000">
<operator activated="true" class="concurrency:loop_files" compatibility="8.2.000" expanded="true" height="82" name="Loop Files" width="90" x="199" y="119">
<parameter key="directory" value="/Users/alkopop79/Datasets/enron_sample"/>
<parameter key="filter_type" value="glob"/>
<parameter key="recursive" value="false"/>
<parameter key="enable_macros" value="false"/>
<parameter key="macro_for_file_name" value="file_name"/>
<parameter key="macro_for_file_type" value="file_type"/>
<parameter key="macro_for_folder_name" value="folder_name"/>
<parameter key="reuse_results" value="false"/>
<parameter key="enable_parallel_execution" value="true"/>
<process expanded="true">
<operator activated="true" class="read_csv" compatibility="8.2.000" expanded="true" height="68" name="Read CSV" width="90" x="243" y="262">
<parameter key="csv_file" value="/Users/alkopop79/Datasets/enron_sample/.DS_Store"/>
<parameter key="column_separators" value=";"/>
<parameter key="trim_lines" value="false"/>
<parameter key="use_quotes" value="true"/>
<parameter key="quotes_character" value="""/>
<parameter key="escape_character" value="\"/>
<parameter key="skip_comments" value="false"/>
<parameter key="comment_characters" value="#"/>
<parameter key="parse_numbers" value="true"/>
<parameter key="decimal_character" value="."/>
<parameter key="grouped_digits" value="false"/>
<parameter key="grouping_character" value=","/>
<parameter key="date_format" value=""/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="English (United States)"/>
<parameter key="encoding" value="UTF-8"/>
<parameter key="read_all_values_as_polynominal" value="false"/>
<list key="data_set_meta_data_information"/>
<parameter key="read_not_matching_values_as_missings" value="true"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
</operator>
<operator activated="true" class="store" compatibility="8.2.000" expanded="true" height="68" name="Store" width="90" x="476" y="268">
<parameter key="repository_entry" value="enron_sample"/>
</operator>
<connect from_port="file object" to_op="Read CSV" to_port="file"/>
<connect from_op="Read CSV" from_port="output" to_op="Store" to_port="input"/>
<connect from_op="Store" from_port="through" to_port="output 1"/>
<portSpacing port="source_file object" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
</operator>
</process>
</list>
</operator>
</operator>
</process>
</operator>
</process>
If you have the Text Processing extension you could do as follows :
Loop files operator -> inside the operator use fil -> read Document -> Documents to Data -> out -> Append operator
Something like this :
