Parameters of a macro
Hi,
I'd like to know if there is a way to let the user give parameters to a macro without those parameters being Flux parameters (IO or geometric).
Simple example: I want to make a macro that computes the parameters of a non-meshed coil. The user can enter the dimensions of the iron core as well as the maximal size of the coil and the thickness of the insulation. Yet, I do not want these input values to be saved as geometric parameters, I only want to keep the four resulting values as parameters that Flux needs. Can I do this?
Thanks in advance,
Romain
