Parameters of a macro
Hi,
I'd like to know if there is a way to let the user give parameters to a macro without those parameters being Flux parameters (IO or geometric).
Simple example: I want to make a macro that computes the parameters of a non-meshed coil. The user can enter the dimensions of the iron core as well as the maximal size of the coil and the thickness of the insulation. Yet, I do not want these input values to be saved as geometric parameters, I only want to keep the four resulting values as parameters that Flux needs. Can I do this?
Thanks in advance,
Romain
Hi,
Not really. We want to work on a documentation, but it will be not available before mid 2018.
To give a small answer, you can use all the entities available in Flux. The special cases are the cases I have give to you :
I04 : integer
R08 : double
C80 : character
You can also look at the macros deliver with Flux to be inspire.
Regards
Yann
Hi Romain,
A member of my team informed me that a small documents already exist (Thanks Abdessamed)
You will find these documents attached.
One on pyflux, python for Flux (Altair_Memento_pyFlux_GB-v2.2.pdf) and the other on the usage of python in Flux (Altair_Memento_python_GB-v2.1.pdf)
These are memento (so you have to print them and fold them into four parts like an accordion)
Best regards
Yann
Hi,
If I well understand your question, you can use input like that :
'''@param NbMaxIterParam I04 1 1 10 Maximum number of iterations (must be > or = to 3)'''
Just replace I04 (integer) by R08 (double) or C80 (character)
Regards
Yann
