Altair RISE
Nominate Yourself Now!
Using regions to apply pressure
User: "timonq"
Altair Community Member
Updated by timonq
Hello,
I would like to import CATIA CAD file to HM with publications. After import I have regions, but I cannot to use it for example to apply pressure on surface. Eventually I want to prepare tcl script to automatic apply BC on surfaces (after mesh). Is there any option to use regions?
Best regards
1 - 5 of 51
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    If you can not do this task in interactive mode, maybe no way to do with a script.
    Share your model?
    User: "timonq"
    OP
    Updated by timonq
    Unfortunately I cannot share my model. But I have access to surfs id in regions:
    *setvalue regions id=20 STATUS=2 simpleids={surfs 87 138}
    So for now I need to only extract surf number to create *createmark
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    Is this a shell or solid model?
    If it is a solid model, i would take a look at SimLab, as it can record a project, with the steps made, such as a script, and also it can have access to some CAD parameters. Take a look at SimLab Learning Center, if you're interested.
    User: "timonq"
    OP
    Updated by timonq
    I tried to work with SimLab, but I have a lot of problems with reading Catia publications to groups (I used SL_PUB_ name before publications name). Sometimes it is working, sometimes it is not... That's why I tried to use HyperMesh (there is no problem with reading publications).
    Anyway, I found solution:
     *createmark surfaces 1 [hm_getvalue regions id=1 dataname=simpleids]
    but command select only first surf id, I don't know why it is skipping other two.
    After
    I have
     309 321 338
    but when I tried to run whole command, only first sufr id was added :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />
    EDIT:
    I found solution. Need to change *createmark to hm_createmark
     hm_createmark surfaces 1 [hm_getvalue regions id=1 dataname=simpleids]
    User: "tinh"
    Updated by tinh
    Use hm_createmark or {*}
    *createmark surfs 1 {*}[hm_getvalue ....]
    Or eval
    eval *createmark surfs 1 [hm_getvalue ....]
