Alyien operator output problems
Jurij
Jurij New Altair Community Member
edited November 2024 in Community Q&A
Hi everyone,
I'm trying to use Aylien Sentiment operator and everything seems fine (it works correctly) until I try to connect the output to another operator. I always get an error message:
And the attribute list of the aggregate operator (in this case) is empty. Same problems with any operator that needs to read the example set from the Aylien operator.
Any ideas what might be wrong?
Thanks.
Jurij
Best Answer
  • Thomas_Ott
    Thomas_Ott New Altair Community Member
    Answer ✓
    Hi Jurij,
    Usually the metadata flows across the operators with no problems but not always. It appears that this is the case.  Double check to see if the Aggregate operator is even connected to the Aylien connector (i see a red input port, that means there's a connection problem).
    If the connection checks out another way to solve this problem is to just type in the name of the attribute (case sensitive) and toggle on "Syncronize Metadata with Real Data" in the Process pull down menu.
Answers
  • Thomas_Ott
    Answer ✓
    Hi Jurij,
  • Jurij
    Hi Thomas,
    Your solution worked out perfectly. Thanks so much.
    Best regards,
    Jurij
Welcome!
Welcome!
