Gravity in forming simulation
Hi!
I am using the RadiossBlock (Block140) in Hypermesh for a forming simulation and I want it to consider the force gavitational, can you please help me?
I already read the tutorials in the page, but I think they are not based in the same Block that I am using, but in he Abaqus (Standad3D) block.
Thank you very much in avance.
Thanks. I am going to try this.
In the Curve ID, what do I have to put if I want the gravity to be during all the simulation? in the values of X the time peiod and in the values of Y, 1 or 9810 ? I mean, I don't know if the function already takes ino account the gravity value or I have to re-write it.
Hi Aurea,
Create a curve in XY Plots>>Curve Editor for gravity load and recall that curve in Curve ID for creating a gravity load. Maintain Scale X and Scale Y values as 1 itself.
For creating the gravity in negative Z direction (as in your model) , either you can provide -9810 value in the function you are defining or you can input Scale Y value as -1.
Use Tools Pull down menu: BC manager. See attached screenshot.
