🎉Community Raffle - Win $25
Join and Win
Server Installation - standalone.sh does not initialize
User: "Ostrowski"
New Altair Community Member
Updated by Jocelyn
I am not an expert when it comes to SQL servers, specially using macOS, but I went through all steps from Server Installation Guide and getting help from a couple videos I finished all intalation steps.
16732037_707933352714286_1063188996_o.jpgConnection successfully established
However, when trying to execute the standalone.sh file I get the message bellow and no acces to localhost:8080. It might be something with the java path, but how to configure it?
Last login: Mon Feb 13 11:11:03 on ttys000
/Users/Ostrowski/Documents/bin/standalone.sh ; exit;
Ostrowskis-MacBook-Pro:~ Ostrowski$ /Users/Ostrowski/Documents/bin/standalone.sh ; exit;
  JBoss Bootstrap Environment
  JBOSS_HOME: /Users/Ostrowski/Documents
  JAVA: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java/bin/java
  JAVA_OPTS:  -server -Xms1303m -Xmx6144M -XX:MaxPermSize=256m -Djava.net.preferIPv4Stack=true -XX:+UseG1GC -XX:MaxGCPauseMillis=50 -Djboss.modules.system.pkgs=org.jboss.byteman -Djava.awt.headless=true -Djboss.modules.policy-permissions=true -Duser.country=US -Duser.language=en -Dcom.sun.jndi.ldap.connect.pool.timeout=300000
/Users/Ostrowski/Documents/bin/standalone.sh: line 310: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java/bin/java: Not a directory
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
Thanks for your time guys!
John Ostrowski
1 - 3 of 31
    User: "mmichel"
    Accepted Answer
    Hi John,
    you can specify the Java path (JAVA_HOME) in the standalone.conf files. If you are starting the server via standalone.sh you need to modify the standalone.conf file. In case of standalone.bat you need to edit the standalone.conf.bat file.
    Cheers,
    Marcel
    User: "Thomas_Ott"
    Ok, I'm not a MAC user but I'm sure there's a way to set your PATH environment variables. I have a JAVA_HOME path set to C:\Program Files\Java\jdk1.8.0_91\ and that does the trick for me.
    Another thing to check into, in Linux had to do a chmod +x ./standalone.sh in the past, it might also be a permission issue.
    User: "Ostrowski"
    OP
    Ok changing the path did the trick!
    It was apparently a bug that when getthing the path from java from System Preferences > Java > Java > View the Path already contained the final "/bin/java" which is applied by default on the standalone.sh. By removing the final extension the installation finished properly!
    Thank you RM Community!
    John Ostrowski
