KNN prediction performance
mehrdad
mehrdad New Altair Community Member
edited November 2024 in Community Q&A
Hello All,
I am new here and I need your help. Actually, I have a training dataset and a test data set to be classified via kNN classification.  Training---->Knn--->apply model and Test --->apply model... I do not want use cross-validation or split validation but can someone tell me how to measure the performance of knn regarding the prediction of classifying my test dataset. I dont know how connected the output of apply model as an input the performance classification to know how good is the prediction of my classification.
Tnx
Welcome!
Answers
  • land
    land New Altair Community Member
    Hi,
    RapidMiner contains some very useful tutorials and explanations for beginners. It's a bit like the tutorials you have in games nowadays to explain what to do. I would recommend to check them out: Click on new process, select "Learn" and then start from the beginning to understand the principle workings and meanings of ports, parameters and colors, etc...
    The chapter 3 of Model, Scoring and Validation will exactly match your question.
    Greetings
     Sebastian
  • mehrdad
    Thank Sebastian,
    I've checked some of them and I got results in the case of using kNN as sub process of cross or split validation but I have no idea how to evaluate  the score of the prediction of data which is shown in the attached pic.
    But-away tnx for your follow up
  • MartinLiebig
    MartinLiebig
    Altair Employee
    Hi,
    the per port of cross validation is already delivering the performance.
    otherwise- you can simply connect the lab port of Apply Model (2) with the lab port of Performance(2) and look at the result.
    ~Martin
  • mehrdad
    Hi,
    Tnx for your reply. u right the cross-validation is already giving us the performance of classification but it is not the performance of predicting test set which is directly connected to the apply model 2. I wanna know that how good is my prediction regarding my classification approach. I wanted to connect out put of apply model 2 into performance directly but I got couple of errors.( it says u dont have label , or u need set criterion, but i dont know how!)
    If you want to know about the dependency of your classification performance with predicting of new test data set (retrieve 08 ), how do u measure it ?
     tnx in advance
  • MartinLiebig
    MartinLiebig
    Altair Employee
    Ahhh, in order to apply Performance, the incoming data set needs to have a the label tagged. So you simply need to use a Set Role operator and set your label variable to label.
    ~Martin
Welcome!
Welcome!
