Hi all,
according to the pivot operator in my data preparation process RapidMiner is experiencing a 'potential problem':
I have to stream a big amount of data.
In Select Attributes I chose three attributes. One of them named TBLUNIQUELRU_ID is being missed by the pivot operator although it is contained in the Select Attributes output data:
Data: SimpleExampleSet: 10000000 examples, 3 regular attributes, no special attributes
A breakpoint is set after the second operator and I can confirm, that the attribute is contained in the pivot input example set.
Code:
<process expanded="true">
<operator activated="true" class="jdbc_connectors:stream_database" compatibility="7.2.001" expanded="true" height="68" name="Stream Database" width="90" x="45" y="34">
<parameter key="connection" value="DB_NAME"/>
<parameter key="table_name" value="ZZ_RM_TEST"/>
<parameter key="recreate_index" value="true"/>
</operator>
<operator activated="true" breakpoints="after" class="select_attributes" compatibility="7.2.001" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34">
<parameter key="attribute_filter_type" value="subset"/>
<parameter key="attributes" value="|TBLUNIQUELRU_ID|BIT|EVENT"/>
</operator>
<operator activated="true" class="pivot" compatibility="7.2.001" expanded="true" height="82" name="Pivot" width="90" x="246" y="187">
<parameter key="group_attribute" value="TBLUNIQUELRU_ID"/>
<parameter key="index_attribute" value="BIT"/>
<parameter key="consider_weights" value="false"/>
<parameter key="skip_constant_attributes" value="false"/>
</operator>
<connect from_op="Stream Database" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Pivot" to_port="example set input"/>
<connect from_op="Pivot" from_port="example set output" to_port="out 1"/>
<portSpacing port="source_in 1" spacing="0"/>
<portSpacing port="sink_out 1" spacing="0"/>
<portSpacing port="sink_out 2" spacing="0"/>
</process>
Can someone help?
Ina
