🎉Community Raffle - Win $25
Join and Win
Connecting to Denodo Server using JDBC
User: "jlozano"
New Altair Community Member
Updated by Jocelyn
Hi Rapidminer commnunity!
I'm trying to connect Rapidminer Studio to a Denodo server as a database adding a new JDBC driver. When clicking on the "Test Connection" button I'm getting the error "attempt to add a Permission to a readonly Permissions object" and I can't continue. Do you know what could be the reason for the error and if there is any way to fix it or debug it?
Thank you for your help!
1 - 3 of 31
    User: "jlozano"
    OP
    This is the log obtained:
    WARNING: Error: Failed to load table data: java.sql.SQLException: attempt to add a Permission to a readonly Permissions object
    com.rapidminer.repository.RepositoryException: Failed to load table data: java.sql.SQLException: attempt to add a Permission to a readonly Permissions object
                    at com.rapidminer.extension.jdbc.repository.db.DBConnectionFolder.ensureLoaded(DBConnectionFolder.java:242)
                    at com.rapidminer.extension.jdbc.repository.db.DBConnectionFolder.getSubfolders(DBConnectionFolder.java:147)
                    at com.rapidminer.repository.gui.RepositoryTreeModel$3.run(RepositoryTreeModel.java:407)
    Caused by: java.sql.SQLException: attempt to add a Permission to a readonly Permissions object
                    at com.denodo.vdb.jdbcdriver.dao.DAOVDBProxy.connect(DAOVDBProxy.java:184)
                    at com.denodo.vdb.jdbcdriver.VDBJDBCConnection.getConnection(VDBJDBCConnection.java:124)
                    at com.denodo.vdb.jdbcdriver.VDBJDBCDriver.connect(VDBJDBCDriver.java:197)
                    at com.rapidminer.extension.jdbc.tools.jdbc.DriverAdapter.connect(DriverAdapter.java:40)
                    at java.sql.DriverManager.getConnection(Unknown Source)
                    at com.rapidminer.extension.jdbc.tools.jdbc.DatabaseHandler.connect(DatabaseHandler.java:273)
                    at com.rapidminer.extension.jdbc.tools.jdbc.DatabaseHandler.getConnectedDatabaseHandler(DatabaseHandler.java:209)
                    at com.rapidminer.extension.jdbc.repository.db.DBConnectionFolder.ensureLoaded(DBConnectionFolder.java:235)
                    ... 2 more
    Do you think this could be caused by the security restrictions explained http://docs.rapidminer.com/developers/security/ ? In that case how can we solve the issue or certify the Denodo's JDBC driver so it can be used with RapidMiner?
    Thanks!
    User: "Thomas_Ott"
    This looks like a permission issue, do you have full read/write access? From the error msg it looks like you only have read permissions?
    User: "Marco_Boeck"
    Hi,
    RapidMiner Studio 7.3.1 contains a workaround for this and should therefore work.
    If anyone is interested, the root cause for this is a bug in Java itself which Denodo runs into when using an unconventional way to communicate with the database.
    Regards,
    Marco
