where to configure R extension dll?
Hi, I have been using R extension without problem before. Recently, maybe because I installed a new R at a different path (used to be C:\, and now C:\program files\R), RM report error about R extension at launch:
can't load IA 32-bit.dll on a AMD 64-bit platform
I read this post and this post. Where do I configure the path of jri.dll?
rapidminer.r.native.lib = C:\Users\rajiv\Documents\R\win-library\2.15\rJava\jri\x64\jri.dll
I thought I could click "Select JRI library file" at the following interface, but it doesn't let me browser to find the path, it just tells me "Found library" (which is the wrong library).
Where can I manually configure this? Thanks-
